-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Flashed car won't start (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/570381-flashed-car-wont-start.html)
SLO-EVO Aug 18, 2011 11:11 AM
The story goes. Working on a car last night. The car had a map in it from an unknown tuner, with unknown mods on the car. Flashed the ECU to a stock map since the car is basically in stock form now. Once the car was flashed, the car will not start. We have tested most means, but am unsure where to go from here. The things I have checked / found:
Checked all fuses. Everything checks out good.
Tested relay in engine bay on another Evo. Good.
When turning the key into the on position, the fuel pump does not prime. It doesn't run at all. Hard wired the battery straight to the pump, and the pump turns on. I have swapped ECU's also, to see if the ECU pooped. Put a stock map on the ECU and the car still won't start. At wits end. I am going to literally start yanking all fuses in the car and relays and seeing if I can hunt this down. Anyone else shed some light for me? Please don't say search either. I searched for about 3 hours and pulled up threads older than dirt. Thanks for the help.
binky Aug 18, 2011 11:19 AM
Did you either disable or enter the correct settings for the immobilizer? If not, this will cause the car to not start.
-Bink
gsrboi80 Aug 18, 2011 11:21 AM
-Bink
:lol: Posted the same in OP's ECUFlash Forum thread
binky Aug 18, 2011 11:23 AM
:lol: :beer:
Good times {thumbup}
-Bink
