-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Ryu's built motor thread (Sponsored by MAPerformance) (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/571028-ryus-built-motor-thread-sponsored-maperformance.html)
RyuEvoIX Aug 22, 2011 06:26 PM
It's been a long hiatus since late October of last year when I broke into the 9 second range with my factory motor. A few days later during cruising one of my factory rods finally gave out after years of 500+whp abuse on a daily basis. Go Mitsu {thumbup} Shortly after I was contacted by Chris Carey, President of MAPerformance, with a sponsorship offer to run their fully built motor setup. I graciously accepted Chris's generous offer. It took a bit of time to gather up the funds for the full build as I did not want to cut any corners or spare any expense but Chris and his team are very patient and easy individuals to work with. I'm happy to say the motor is finally here and ready for assembly. :) On to some pictures
As you can see, great care was taken for the shipping process. Thanks MAP {thumbup}
http://img.photobucket.com/albums/v5...e/100_5232.jpg
10:0:1 custom Weisco pistons with extra large valve relief ports.
http://img.photobucket.com/albums/v5...re/Picture.jpg
Stage 3 MAPerformance ported Evo IX head
http://img.photobucket.com/albums/v5...e/100_5240.jpg
Exhaust ports with high quality MAPerformance port work
http://img.photobucket.com/albums/v5...e/100_5236.jpg
http://img.photobucket.com/albums/v5...e/100_5235.jpg
Intake ports with high quality MAPerformance port work
http://img.photobucket.com/albums/v5...e/100_5239.jpg
http://img.photobucket.com/albums/v5...e/100_5237.jpg
Beautiful bowl work w/ 5 angle valve job
http://img.photobucket.com/albums/v5...e/100_5244.jpg
Assembling the head
http://img.photobucket.com/albums/v5...e/100_5243.jpg
More updates to follow. :)
9SecSLC Aug 22, 2011 06:35 PM
Keep us updated! Which turbo are you going with?
E-Spec@Tach Motor Works Aug 22, 2011 06:37 PM
In on the first page!! Good luck!!
RyuEvoIX Aug 22, 2011 06:44 PM
I'll be sticking with the hta82 w/.63 hotside for now. I have a goal of 9.7@142mph in mind for this turbo setup that I believe I can reach without too much trouble. Ignition timing at peak boost (38psi) previously was 1 deg advancing to approx: 14 degrees out the top just to give an idea of what should be left in the tune on this turbo setup without the addition of the more efficient flowing head, slightly better cams, and higher compression as well. Once that goal is acomplished, then I'll be stepping up to an hta86 with a 9.3-9.4 @148-150mph goal. :)
n2oiroc Aug 22, 2011 06:49 PM
i wanna be sponsored. :mad:
*nobodyputsbabyinthecorner*
SOEuro Aug 22, 2011 07:08 PM
go 10s on stock turbo/stock block...that might help
n2oiroc Aug 22, 2011 07:11 PM
:lol: probably. im not bothering with that stock turbo jibber jabber. strait to 750whp!
op, congrats on the sponsorship! map is a fantastic company to work with!
murlo26 Aug 22, 2011 07:30 PM
Wow! Looking great Ryu, GL with the goals.
B.J.@ToxicFab Aug 22, 2011 07:39 PM
Looks good, good luck sir...Looking forward to updates!
RSMike Aug 22, 2011 07:50 PM
Does anyone know what the "B" shaped exhaust port does?
Ramonski Aug 22, 2011 07:57 PM
Looks great bro and good luck...cant wait to see results...also bump for a LOCAL! Lol
BigT Aug 22, 2011 08:34 PM
It looks like it is a diversion of the exhaust gases to a straighter path out of the runner vs colliding into each other. Just a guess though. :beer:
RyuEvoIX Aug 22, 2011 08:40 PM
This would be my reasoning as well.
ChrisCarey Aug 23, 2011 02:14 PM
Looking good sir, can't wait for it to hit the drag strip!
RyuEvoIX Aug 23, 2011 02:42 PM
Thanks Chris. {thumbup} I can't wait to get back out to the drag strip to accomplish my next set of goals. By the looks of the high quality motor work by your company, I don't think it will be too terribly hard to accomplish them. :)
