Car temperature rising at higher speed
while going to work today, i was on the turnpike just going northbound, i was in 5th gear and as my speed rose to above 85 or so lol yea i know i shouldnt have been going that fast.
anyways the temperature gauge in the dash went from normal to almost hot.... as i eased off the gas and started slowing down, the temperature also went down. mind all of you this is the first time my car has EVER done this. the car is an 05 gsr with 45,700 miles. so my question to all of you is WHAT THE HELL IS UP WITH MY CAR? should i check the radiator fluid level? or could this be a sensor issue ? thanks for any help {thumbup} |
Yeah, it could be low coolant, it could be a bad thermostat, it could be a bad sensor. It also could be a blown head gasket.
Check radiator first. If the car overheated you should change the thermostat too. |
well so far the car is good, it just keeps on almost going to hot, but as i ease off the gas say when im the highway it will start to just go down slowly near the normal temp area. while im driving in say stop and go traffic the car is acting perfectly fine.
my sti did that and at higher speeds the temp went up....just cruising aroung little to no boost the temps were fine...but the min i stepped on it..air got in the system overflow tank was bubling and the end result was a blown head gasket
Your headgasket needs to be replaced, I 'd replace it before it blows out all the way.
Check your coolant level
and check for contaminated coolant and or oil.
i think i'll check the coolant levels first, i doubt the head gasket could have blown out. i drive the car occasionally, and i definetly dont dog it. i'll post when i see how the coolant levels are
the coolant tank was LOW, so im going to add some in and give her a spin in a little bit. i hope thats the only problem.
Add it directly to the radiator.
Originally Posted by turbodoug
(Post 9672508)
Originally Posted by donmeca2020
(Post 9672625)
the radiator looked to be good. the coolant tank was at the low point on the tank. so i just bought some coolant and will add it in a little bit
we shall see ....
i filled up the coolant tank, afterwords took the evo for a spin around the neighborhood. once again at regular speeds seemed perfectly fine. now when i went on to a main street and gunned it it was ok , and i tried once again the temperature slightly went up. im curious as to should i check out the thermostate or possibly a sensor. if not then i'll be making my way to AWD motorsports monday morning and having them check it out..... ****ing sucks i hate having my car not functioning correctly
