Stuck in gear when shifting at high RPM's
Has anyone had a problem with their car getting stuck in gear when trying to shift at around 7K?
It will come out but it takes a lot of effort. It's also intermittent although that might have to do with the speed with which I'm shifting I also have super notchy shifting so I thought it might be my clutch not disengaging fully......but I pushed the clutch in, put the car in gear, stutterboxed, and the car does not creep so I think I can rule that out This is a '06 IX with a 5-speed |
Bump this. I'm getting this on my 9 RS did you ever figure it out? Thanks!!!
its gotta be the clutch. how high did you rev when checking for creep? 1st gear?
I never figured out what it was because a couple of days after posting this, the assembly that disengages the clutch came apart and seized everything up so I had to drop the trans. It was kind of a jumbled mess so never took the time to see what actually failed.
Lol. Didn't realize that it was such an old thread.
| All times are GMT -7. The time now is 09:46 PM. |
