Injector seals, on the cheap from O'reilly's Auto Parts
I know everyone has been in a pinch and needed the big injector seal that goes into the intake mani... I needed some today and after doing a bit of research I ran across some at O'Reilly's auto parts. It is a seal kit for a 2000 Toyota Tacoma 2.4, Borg Warner Fuel Injector Seal Kit, Part Number: 274531. The kit is $3.99 per injector, however it was a tad cheaper with the ole military discount... Thought this might help if you can't wait on them from the dealer!
http://images.oreillyauto.com/parts/...d/274531_1.jpg |
Thanks!
No doubt
Good to know, thanks for sharing Freddie!
Guess none would come up if u looked it up under an evo?
good stuff as always Freddie, thanks
Thanks guys!
Originally Posted by My03evo
(Post 9943121)
Or $4.59 from NAPA part number 2-12069.
Man, what timing. I'm planning on getting my car tuned next weekend, did another boost leak test just for sh*ts 'n' giggles, found out that one of my injectors is leaking upwards of 26psi.
I'll have to run up to oriellys and see if I can't get a few sets of these. Thanks man! |
Nice! How'd you figure that one out?
If all the seals in the kit fit our injectors, let me know and I'll put through a catalog update for it. |
All of them do minus the big o-ring, which doesn't fit anything...
Originally Posted by Freddie@Spec-Ops
(Post 9994473)
Getting an E85 smell from near the injectors so I just picked up this kit 274531. Curious why the above quote notes to use all the seals except the large one. To me the 2nd & last from left are the only ones to use EDIT: Freddie PM'd me. Got it figured out http://images.oreillyauto.com/parts/...d/274531_1.jpg |
This kit did not work for me. Performed the install using the 3 seals (upper, lower & the seal below the uppers (channeled seal) Note: The channeled seal does not fit the RC injector. So I only used the upper seal
Cranked over the motor (did not start) & immediately had a small fountain of corn juice pissing all over. Checked to find fuel leaking at the bottom seals. Removed everything & measured the OEM bottom seal vs the BWD. Huge dimensional difference in O.D. & I.D. Anyway, Used my original bottom seals & used the BWD upper seal. P.S. The reason I changed my seals is that I had a small fuel leak somewhere at the injectors. See torn upper seal bottom left IMO. This BWD kit is not right Peace, Joe https://cimg2.ibsrv.net/gimg/www.evo...827ff9259b.jpg |
Lube with vaseline and squeeze
Military discount for the win. I love when people give me those...makes me sad when others dont!
| All times are GMT -7. The time now is 08:11 PM. |
