scary transmission noise
i have never heard a noise like this before.
my car has a new mildly built transmission and a new southbend 6 puck ceramic clutch in it. after about 2000 miles of running the new setup i have run into disengagement problems at high rpms and now when i start the car it sounds as if there is change jingling in the bell housing, if you speed up while driving you can still hear the noise but it sounds more like a grinding/faster chatter. still have the engagement problems any ideas? my buddy who has worked on evos for years says it could possibly be the starter making the noise the disengagement problem is for a nother day i can figure that one out but any ideas concerning the source of the jingling noise? bearing let loose in the trans etc? |
What is jingling noise? Lolz
Im just guessing...If you can hear that at idle, i will say it could be throw/pilot bearing. |
it makes no noise at idle. but you can hear it when youre driving around 45 mph next to a wall or another car.
the jingling noise sounds like theres change jingling in like a coffee can |
bump :(
no thoughts???
