fidanza aluminium or chromoly flywheel??
hello i want to know which is better?? fidanza aluminium or chromoly flywheel??
with Fidanza you can change the metal plate each time you change the clutch disc, but whats about the chromoly?? thanks |
Get a one piece steel fly wheel or use your stocker. I now use an ACT one and havent had any problem since that nightmare.
i didnt know about fidanza problems.. thanks
Never Reuse a Chromoly Flywheel
I had a Chromoly Flywheel but after a had it resurfaced then I could not get a new disc to seat. I put on 1000 miles no boost and still the piece of junk would not hold the power. I had I adjusted properly but it would not hold power. If you do get a Chomoly flywheel then you need to buy a new one every time you change the clutch. Trust me... go with Alumimum flywheel and save your self pain and suffering.
