Wideband formula help. Innovate MTX-L ---> EvoScan
:helpme: Im trying to determine if the new Innovate MTX-L wideband formula should be the same in the EvoScan software as the older LC-1 since EvoScan already has formulas for the LC-1. If anyone has had any experience using the MTX-L with EvoScan please let me know. Any help would be greatly appreciated! Thanks. :mitsu:
Im wiring the wideband output directly into the ECU wire (rear O2) and using that to log with instead of serial or USB. So im assuming this will work with any wideband this way, but im not sure if the formula is correct. (the range on the MTX-L is from 7.35--->22.4 for gas so thats why I used those values.) 7.35+(7.35-22.4)+x/255 |
anyone else using MTX-L?
Mtx-l
From what I can tell so far, the MTX-L gauge is reading almost identical to the log output on EvoScan. The hard part is watching the gauge and the laptop at the same time, but so far that formula seems to work ok
