-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Drivetrain guru's looking for a educated guess (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/607557-drivetrain-gurus-looking-educated-guess.html)
SmurfZilla Apr 16, 2012 12:08 PM
My cars drivetrain has been an odyssey to say the least.
Lets start from the top.
When my motor grenaded it took the transfercases housing with it and unbeknownst to me cracked the bell housing on the transmission (This will be important later).
I drove the car for a few weeks after my tcase started doing the deathwhine (Built tcase from Shep). After a few months I found a stock tcase to swap in while i get the money up to rebuild the built tcase with Shep again (I think the tcase shouldn't have gone out since i never launch the car, but I can't prove the previous shop filled it improperly).
While I was waiting for the tcase to become available I discovered that I was getting high rpm lockout on my carbonetics triple carbon clutch. When I finally put the car down the carbonetics was in such bad shape it was determined by ATS themselves that either car was abused badly (For sure not) or it was clutch assembly gone horribly wrong or install gone horribly wrong. The middle plate was broken and the whole clutch was toast. Only thing that was re-usable was the clutch cover.
While I was waiting to find out what was wrong with my clutch I had asked a few questions online and had a few people reach out to help when the clutch came out (94AWDCoupe and Patrick from FFTEC specifically) as well as some board members give their opinion. Bottom line I got f v c ked again. Had a shop mic the input shaft on the trans and speak to Shep and they both agree I dodged a bullet so we decided not to send it to Shep to check out. ATS for the record is amazed the transmission is in one piece.
SO I decided that rebuilding the ATS wasn't an option (they wanted essentially the same money for a brand new clutch) and all the drama with the Exedy triples started coming to light so I decided to go with the Quartermaster (I had a possible opportunity to try Competition Clutches new triple out but that kinda evaporated).
Get the quartermaster in and everything is cool. Car is different to drive but getting used to it. I move to Raleigh and they DONT PLAY with speeding so I have been taking it easy for the most part (plus I'm on a 93 gas tune so power is down ALOT....about 550ish).
One day out of no where i get a horrible metal on metal sound and the car acts like it wants to shut off. Then when I its driving I feel vibration in the pedal I never felt before. I call Spec-Ops and decided to haul ass to Fayetteville (from work thats an hour and half drive).
Once I get the car out of 1st its fine. So the whole car ride there with the exception of the vibration in the pedal it drives fine.
I get to spec-ops and after a few minutes of looking the car over they realize the trans is literally coming off the block. Luckily my wife is in town with my kids so she comes and gets me and we go home and wait for Spec-Ops to call me with their diagnosis (they are afraid that I might've damaged more then we saw.
I dropped the car off on Friday while they had a lot of stuff going on. They get the car on the lift on Tuesday the following week. Drop the oil pan and everything is perfect (Thank god). Flywheel and starter are chewed up. Pressure plate bolts are loose and the bellhousing has hairline cracks in it which in turn allowed the dowel pins to get loose, missing a bolt on the backside of the trans.......its all bad.
So Spec-ops has determined that the clutch/pressure plate, starter issues were due to improper installation and the trans separating from the block was then likely due to the bellhousing being cracked.
Trans "APPEARED" to be ok but Matt wants to send it to Shep to have them inspect (and might as well have then replace the bellhousing while their at it.
SO after all this drivetrain drama I guess my question is:
"How likely is it that my input shaft is bent"? I know this is all speculation but seeing as how I don't have jack to do until my transmission comes back from Shep (they said 2-3 weeks last week od only knows how long it will actually take) I'm trying to mentally prepare myself as to what Shep may find (this was a previously built trans from them as well). The last shop before Shep thinks the clutch could've been screwed due to a slightly bent input shaft (which is why we are sending it off to Shep) but its going to be hard for Shep to know what happened when and how to assign responsibility.
What do you guys think?
Acree Apr 18, 2012 11:18 AM
Send the entire car here. :D
-Acree
redridingboost May 9, 2012 04:25 AM
So basically it all began with "Install Error" ?
Liqquid May 9, 2012 04:40 AM
for the trans to back off the block and loosen up dowels, bolt fell out.. that has to be some horrible imbalance or a failed clutch install.. so that's where you're at right now, trying to figure out if the clutch was installed wrong, or if there is some existing issue with engine or trans creating the broken clutches, right?
dastallion951 May 9, 2012 10:29 AM
To me sounds like a lot of headaches, i went through a few myself working out a couple of clutch issues, it could've been improper installed. Or whoever might have put the trans in the dowel pin might've been missing or the bellhousing bolts could've been overtorqued. Anything is possible main thing is your shop you did the work with should help. Thats all I got. Sorry to hear man, hope things work out.
Good luck
AreSTG May 9, 2012 01:40 PM
hope this gets worked out as cheap and quickly as possible. So what's with the cops in Raleigh? i generally speed the whole time on 40 and 440, though your definition of speeding may be different then mine. but i don't live there, driving it every day.
