-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   What's this I found in my sump (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/610702-whats-i-found-my-sump.html)
craigybaby37 May 7, 2012 11:39 AM
Hi all iv had another engine failure so now on rebuild no.3 but this time round someone is building the engine for me.
Anyway I was outside this morning cleaning my sump out when I knowntised a little spring sitting in the sump?? I have an AMS sump with 2 trap doors but these don't have springs on them so I'm string to wonder where it's come from.
Also there was a green rubber ring about 1cm across in there aswell, I'm starting to think weather it's something like the turbo oil seals??
Here is a picture of the spring the yellow square it's sitting on is about 1 inch across
http://img.photobucket.com/albums/v3...7/94bce62b.jpg
I haven't got the rubber ring anymore as I lost it so can't put up a photo sadly.
Thanks
Craig
Drifting Away May 7, 2012 11:49 AM
Ummmm that would scare me if i found that in my oil sump
khmerpimpin May 7, 2012 11:51 AM
Valve seal ring?
craigybaby37 May 7, 2012 11:57 AM
Just been and looked at the head and turns out 2 of the springs are missing from around the valve stem seals :-(
What could of caused them 2 come off?? They were installed by the machine shop could they be installed incorrectly or damaged when fitted??
craigybaby37 May 7, 2012 10:42 PM
Could it have anything to do with the fact I have ferrea 6000 series valves on stock valve seals?? Maybe the ferrea valves are slightly thicker that stock valves???
