clutch pedal sinking
i was driving home tonight and got to a light in town and stopped. when i went to drive of the clutch pedal didnt leave the floor however the car did manage to not stall out and drive off. i pulled the pedal up with my foot and shifted threw the gears fine (mashing the clutch pedal) it seems to try to go soft but i only pressed it long enough to shift gears. i got home and pumped on it a few time and its stiff but if i leave pressure on it itll stick to the floor. ive checked the fluid level and for leaks and there are none. do yall think ive blown my slave or master.
thanks, Enjoi |
I have the exact same issue I'm thinking either A: I need to verify no air in the system by bleeding or B: replacing slave cylinder.
Originally Posted by cudude11
(Post 10217089)
I had this issue on a previous car a new slave cylinder fixed it. However, while your at it go ahead and replace the master too.
Maybe upgrade to SS lines to avoid having to bleed it again if you decide to upgrade them in the future. :) |
