What Conventional Oil's do yah'll use for Break In?
Hey EvoM,
I'm sure there's a thread, but it wasn't titled appropriately so I couldn't find it, hence this thread. I just wanted to see what everyone else was using for their conventional oil during in the break in period of their motor. I've found that Super Tech from Wal Mart actually has a great ZDDP package and is super cheap. Thus, that is the oil I use! This was an analysis done after 4800 miles on a Scion TC that had the life beat out of it. http://i70.photobucket.com/albums/i9...eportFINAL.jpg It has a very decent ZDDP package as well: 10W-30 Physical Specifications Procedure Test Min Max Typical Results ASTM D4052 Specific Gravity at 60̊F NA NA 0.8714 ASTM D287 API Gravity NA NA 30.88 ASTM D445 Viscosity at 100̊C, cSt 9.3 <12.5 10.44 ASTM D445 Viscosity at 40̊C, cSt NA NA 69.53 ASTM D2270 Viscosity Index NA NA 137 ASTM D1500 ASTM Color NA NA 2.5 ASTM D5293 Cold Cranking Simulator, cP NA 7000 6301 ASTM D5185 Zinc, % mass NA NA 0.085 ASTM D4951 Phosphorus, % mass 0.06 0.08 0.072 ASTM D5185 Calcium, % mass NA NA 0.214 ASTM D5185 Molybdenum, % mass NA NA 0.008 ASTM D5185 Boron, % mass NA NA 0.023 ASTM D4951 Sulfur, % mass NA 0.5 0.357 ASTM D5762 Nitrogen, % mass NA NA 0.102 ASTM D874 Sulfated Ash, % mass NA NA 0.92 So, lets hear what conventional oils are best for break in (not including first start up, as SAE30 break in oil is recommended/used by most). |
Just based off preference and not really knowing "facts" I used Valvoline 10w30 when breaking in all the Honda motors I've built, always heard good things about their conventional for breaking in and never had any problems with setting rings with it.
I used Valvoline 10w40 for brake in!
I use 20w50 vr1 racing oil the non synthetic. For first start up/break in. with bottle of zinc break in. I've used it in all my dsm engines and race car engines (350). never had a problem. Than change around 500-750 miles. Northland is nice to.
Can i use Shell Rotella T1 for first start up and first tune?
Originally Posted by 2006GSR
(Post 10257456)
Advanced Auto oil is the same as Valvoline, so that is a great cheap alternative as well!
full BR 2.3 build...I run brad penn 20w50
it's relatively cheap compared to amsoil and such |
Originally Posted by mullen
(Post 10258240)
Do whatever MAP tells you since it is there motor, that way they will cover you
(Post 10258255)
Originally Posted by Blue91lx
(Post 10258260)
Oh, I hear yah. I just made this thread to compile a list of high-zinc level conventional oils that are conducive to a healthy break in.
http://www.amsoil.com/storefront/images/BRK_300.jpg |
Originally Posted by apagan01
(Post 10258773)
Many shops and evos are using this, and i think MAP is one of them:
http://www.amsoil.com/storefront/images/BRK_300.jpg This thread is to point out the conventional oils people are using AFTER the first startup, BEFORE they start using a synthetic. Yes, we all use Amsoil break in for the first start, but it's far too thin to run during the whole break in process. |
(Post 10258840)
:lol: This thread is just dumb now.
The conventional oils people are using AFTER the first startup, BEFORE they start using a synthetic. Yes, we all use Amsoil break in for the first start, but it's far too thin to run during the whole break in process. |
Originally Posted by Piro Fyre
(Post 10258863)
The Amsoil SAE30 oil is NOT a synthetic oil...
| All times are GMT -7. The time now is 10:20 PM. |
