evo 8 ACD system and pump pressures? cant seem to find info on it.
Im relocating my acd pump on my evo 8 and am trying to source some custom hydraulic lines for it but I was wondering how strong they needed to be. I cant seem to find info as to what type of operating pressures the acd system and pump are under and just wanted to make sure I use a durable enough line on it. Does anyone know what pressures the pump puts out typically so I have an idea of what I would need?
max pump operating pressure is 20 bar, however, in use I doubt you will see more than 16..
Earl lines!!!!!
Thanks. That was sort of what I was estimating about. I already sourced out some ss braided line with AN fittings from a local hydraulic shop. Did a mock mount up of the pump in the trunk and got the line somewhat routed in the general direction I want for now. Next step is to get the wiring back to the trunk.
