-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Pte 6262BB won't spool on 2.0L block. (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/626642-pte-6262bb-wont-spool-2-0l-block.html)
GBAILEY472 Aug 29, 2012 06:39 AM
Hey, Car was on the Dyno yesterday, and we couldn't get the turbo to spool. It would hit full boost (17Psi) at 7500rpm and at 3000rpm -200 Trq
We did boost leak, compression, leak down... all the tests were properly done..
Anyone have and idea ? So far, Ive been told my injectors are to big 1425 for 94oct. and my GSC S2 cams might be an issue also..
Please help me out guy's
Thanks
MOD LIST
MAP T3 Exhaust manifold
MAP 3inch downpipe
Precision 6262 Ball Bearing turbo PTE 6262BB
4"ported inlet 2.5 outlet
T3 Vband .82 a/r
Custom 3inch Upper intercooller piping ( Short route)
Battery delete ( in trunk )
AMS F1 Intake Manifold
AMS Fuel Rail
Boomba Throttle body
1425 Injector clinic injectors
Spoolin coil on plug system
ETS Intercooler
MUSE LICP
TIAL BOV
TIAL 44mm external Wastegate
Wiseco Coated piston 9:0:1
Manley H-Beam Rod
Cometic Head Gasket
ACL bearings rod
ACL main bearings
ARP Headstud,
ARP Mainstuds,
Brian Crower Single Springs
Bran Crower Titanium Retainers
Balancer shaft Delete kit
Areomotive 340L Fuel Pump
GSC S2 Cams
Vi-Pec ECU Standalone System
Aquamist HFS-5 Meth Injection with Guage Display
AEM OIL pressure guage
AEM Boost Pressure guage
Grimspeed Electr. boost controler,.
Omni 3 Bar map sensor.
NGK wideband
STM SS Clutch Lines
JM Fabrication SS Lower radiator pipe
JM Fabrication SS Upper radiator pipe
Moroso Oil Catch Can
Sheptrans Stage 3 Transmission
■New 1st gear synchro
■New 1-2 shifting sleeve
■New 2nd gear synchro
■New 3rd gear synchro
■New 3-4 shifting sleeve
■New 4th gear synchro
■New 5th gear synchro
■New 5-R shifting sleeve
■New Reverse Synchro
■New input shaft seal
■New shaft end seals
■New axle seal
■New 3-4 fork
■New input shaft bearings
■New high strength roll pins
■New 1,2,3,4,5,R synchro springs
■Neodymium magnet
■Bead blast
■New thrust plates
■New thrust plate retainer
■New Oil guides
■Shims
■Billet output tube
■4.11 final drive upgrade
■ REM ISF gearset with rails and hub/sleeve
Sheptrans Stage 3 Transfer Case
■CAD engineered Klinglnberg Palloid tooth profiles
■No reduction in tooth width along the gear
■Robotic CMM scanned for tooth profile perfection
■Computer controlled heat treatment
■Anti-fatigue shot peening treatment
■8mm to 10mm bolt upgrade
■New pinion bearing set
■New seals and o-rings
■Reshimming
■Neodymium magnet
■ Quaife LSD
Sheptrans Upgraded Rear Diff
Exedy Twin carbon Disk Clutch
Techna-Fit SS Clutch Line
Fidanza short throw shifter
AMS Delrin Shift Knob
nyc 93-2jzgte Aug 29, 2012 06:43 AM
have you checked the condition of the turbo? perhaps it is blown. an smoke at WOT or in/out shaft play?
DDATuned Aug 29, 2012 06:48 AM
Sounds more like a turbo issue. Take the turbo off and check compressor and turbine blades.
Steven Aug 29, 2012 07:18 AM
It is for sure not the cams and those injectors should have no problems on pump gas. It's most likely a problem with the turbo or wastegate. Is the wastegate stuck open? Is there any strange noise or smoke while the turbo is spooling? Will the car idle and cruise correctly?
Pirana Aug 29, 2012 07:19 AM
sounds like a wastegate/boost controller issue.
GBAILEY472 Aug 29, 2012 07:37 AM
Turbo is brand new... no issues. Wastegate is unplugged ... plz keep sending ideas guys,
Steven Aug 29, 2012 07:41 AM
The Grimmspeed boost controller is unplugged therefore running wastegate pressure?
goosey2099 Aug 29, 2012 07:43 AM
^ and that would make about 17 psi
GBAILEY472 Aug 29, 2012 07:44 AM
yes
masonh Aug 29, 2012 07:45 AM
sounds like a winner,check and see if you have the 17psi spring in the WG and if so,you know that's what's up.
GBAILEY472 Aug 29, 2012 07:47 AM
but then why would only hit full boost at 7500rpm ?
okevolutionVIII Aug 29, 2012 07:48 AM
Wastegate or BOV bleeding off air is my guess.
Steven Aug 29, 2012 07:57 AM
Pull your wastegate outlet/dump and see if the valve is stuck open. If you have a dump tube, I usually undue it then use a mirror and flashlight to look at the valve. I use a bicycle pump with a gauge to pressure the lower port on the wastegate to ensure it is opening at the proper pressure and doing it smoothly.
Are you running a catalytic converter that could be clogged/broken?
Pirana Aug 29, 2012 08:42 AM
bang, right on the kisser!
wreckleford Aug 29, 2012 08:56 AM
If that all checks out ok then check that you don't have any rags or newspaper stuffed in your intercooler piping from when the car was taken apart. I've seen that happen before, found it in the intercooler inet.
