-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Any experience with MAP's 2000cc injectors? (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/628919-any-experience-maps-2000cc-injectors.html)
SmurfZilla Sep 16, 2012 12:56 PM
I was all set to buy another set of FIC 2150's but I noticed MAP has 2000cc injectors. I know they are made by BOSCH but I'm looking for some direct experience with these.
HyboostN Sep 16, 2012 01:20 PM
Why were you going to buy another set of 2150's? DID they fail ?
SmurfZilla Sep 16, 2012 07:50 PM
Nope. New motor. New car. Looking for things to be done RIGHT this time. No more little annoying issues.
SmurfZilla Sep 18, 2012 06:06 AM
Soooooo.....no experience. GOt it. Looking for a set of 2150's then.
Boltz. Sep 18, 2012 10:50 AM
I am currently using the MAP 2000's on stock ecu and speed density.
In the midst of tuning but thus far they are working very well. No complaints.
evilempire76 Sep 18, 2012 03:07 PM
From what I understand ID, FIC, and now MAP all use the same Bosch injectors, but they have different housings on them.
JohnBradley Sep 18, 2012 04:59 PM
They work similar to the FIC2150s but they dont seem to be exactly the same. Hard to say since I am not tuning the car in person...too many variables.
We use FIC2150s with great success.
SmurfZilla Sep 19, 2012 06:34 AM
Ok so possibly on the table again.
Thanks for the input guys. I may use them after all.
Spec-Ops1 Sep 19, 2012 06:56 AM
Smurf, I know not MAP, but I used a set of Slowboy 2000cc which uses an oem bosch injector like fic and ID, just with a different top hat and never had any issues with them... switched to FIC as that is what we recommend and sell...
Alpha X Sep 19, 2012 07:02 AM
I have a set of there 1000cc injectors on my car with PnP. Running E85 on them for a week now. So far so good :)
Not the same as the 2000cc injectors but it's something.
project_skyline Sep 19, 2012 12:36 PM
What sort of difference will the tops make? Balance, flow pattern, or what?
Routybouty Dec 2, 2012 09:27 AM
Bump, any new testers want to comment? :D
gotpsi? Dec 2, 2012 09:33 AM
They are all the same, the tops are just a machined piece. The only difference is if one company buys more at one time they can better flow match sets. This is done by testing the injectors and putting alike ones together, because there will be some variants in flow for each one.
way2qik Dec 2, 2012 01:54 PM
The advantage of the ID2000s is that they are flow matched. Other than that, they are all basically the same.
Routybouty Dec 5, 2012 09:30 AM
I thought ID injectors were latency matched?
