-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   I'm about to go redyno. How far should i push my stock engine (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/634262-im-about-go-redyno-how-far-should-i-push-my-stock-engine.html)
riceball777 Oct 29, 2012 04:11 AM
my stock engine and car has 120,000 miles. For the majority of the engines and cars life it has been at 400whp running 91 octane. I drive a lot!!!! I drive the car 100+ miles a day with ac in stoap and go traffic. I take long trips in the car and I even drag and autocross the car a few times a year. So far at this power level and setup the car has been dead reliable.
Its more or less a hta gt3582r turbo with a full race twin scroll manifold with all supporting mods.
I just swapped out the hks 272 cams for gsc s2 cams and valve springs. I'm going to go redyno this week on 91 octane and I will also get an e85 tune.
Now my setup is cabable of 700+whp. I don't want the car to blow up. It will be driven on 91 octane 99% of the time.
How far should I push it on e85?? 450whp? 500whp? 550?
heres a pic of the engine bay
http://i28.photobucket.com/albums/c2...r/CIMG5644.jpg
lostsoulsevo Oct 29, 2012 04:54 AM
be more worried about torque if anything, especially if you're dragging and autoxing on the weekends. i would personally stay around 400tq, as for HP...you should be upper 4 or low 500. goodluck ;)
1d10t Oct 29, 2012 08:44 AM
Good advice ^
MechTech Oct 29, 2012 10:26 AM
Just retune and shoot for the same numbers. Did you swap cams to try and gain power?
wazzelby Oct 29, 2012 10:46 AM
I'm confused on what you have. The thread says "stock motor" but in your post you say you have all the supporting mods. If it's capable of 700+hp, then you shouldn't' have anything to worry about if you're staying at or below 500.
But like someone mentioned above, with E85 you're going to see a lot more torque. That's where you'll find your weak points in your build.
riceball777 Oct 29, 2012 11:01 AM
I meant my turbo setup is capable of 700+whp.
More of less I have a stock 120,000 miles block with a
Hta gt3582r, t4 1.06 divided hot side, full race twin scroll manifold. With all supporting mods.
