-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   THE BUILD! He's Back! ...and looking for parts! (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/646392-build-hes-back-looking-parts.html)
Raceghost Feb 11, 2013 09:03 PM
Hello all. Been really busy for a bit. Finally getting around to putting Bettie back on the road. To do so, I have very long and distinguished parts list. If any of you vendors, could put together your best quote and email it or instant message it to me, i would really appreciate it. I have phoned MAP a month ago, had this list put together, then called back, only to leave a message, with no call return. So I'm shopping... My rings are at approx. 45% gone. She's blowing oil like the Deepwater Horizan well. May as well do the glory build while we have it all out on the bench. Time to get serious. Please help me spend some money vendors. :helpme:{thumbup} :beer:
I took these lists off of vendors websites on this forum, only because it was a great list and what I want in parts. I will be doing all labor.
Transmission Parts:
•1st gear triple synchro rings
•1st gear triple synchro spring
•1-2 slider
•2nd gear triple synchro rings
•2nd gear triple synchro spring
•3rd gear double synchro rings
•3rd gear double synchro spring
•3-4 slider
•4th gear synchro ring
•4th gear synchro spring
•5th gear synchro ring
•5th gear synchro spring
•5-R slider
•Reverse gear double synchro rings
•Reverse gear double synchro spring
•Modified roll pins so they won’t back out for 1-2, 3-4, 5-R
•New oil seals (input and output)
•New and revised set of input bearings
•EVO9 1st gear and input shaft
•HKS 4.11 final drive gears with new intermediate shaft
ACT Prolite Flywheel
ACT Street Light clutch or competitors
4G63 2.0L Rebuild. This gets a little bit harder.
Bottom End Parts:
Crankshaft: Manley Forged (190100)
Connecting Rods: Manley I-Beam (14403-4)<H Beam option?>
Pistons: Wiseco 1400HD .020" Over (K626M855)
Bearings: ACL Main & Rod + Thrust (5M1219H-STD & 4B1185H-STD & 1T1219)
Main Studs: ARP (207-5401)
Anything else I am leaving out?
Top End Parts:
(8)Supertech Black Nitride Exhaust Valves (DSM/Evo) Standard sizing
(8)Supertech Black Nitride Intake Valves (DSM/Evo) Standard sizing
Supertech Exhaust Set of 8 Valve Guides (DSM / Evo 4G63)
Supertech Intake Set of 8 Valve Guides (DSM / Evo 4G63)
Supertech Complete Valve Seal Kit (DSM / Evo)
HKS Set of 16 Single Valve Springs (DSM / Evo)
HKS Set of 16 Titanium Retainers
Open to suggestions on the Valve Locks...
DO NOT NEED CAMS, I ALREADY HAVE KELFORD 272's in good condition.
Thanks in advance to all vendors that take a look and submit a price or quote for me. I really appreciate it. Look forward to hearing from you all!
Thanks again,
The Ghost.
Raceghost Feb 18, 2013 02:10 PM
Bump! No one wants to PM me a price or anything...? :rolleyes: Ok. Well :beer:
Sorry, If have posted this in the wrong location, will a moderator please move it to the correct location. Thanks in advance. Sorry, been very busy. Was hoping to see some action on this over the last week. Thanks again.
