REQUIRED: Boost leak tester for Tomie M7960
Hi Guys,
I know I will get flamed for this, but hear me out first. I am looking for a boost leak tester that will fit onto my Tomei M7960 turbo. I would like a tester with a gauge on it that shows psi and Kpa, up to 37 psi. The air inlet should be a tire valve. You guys may be thinking you can get that anywhere, heck you can DIY it, why ask in the forum....?? So here is the big but! I live in a place that have very little DIY parts available for cars. No local mechanic would do a boost leak test for you, there reason they say is.... "if there was a leak big enough you would notice. If you don't notice then the leak is no a major issue, so no need to test for boos leak!' PALM------>FACE--->HARD!!! This stupid place is called HONG KONG! So if any of you guys are kind enough to point me to the right direction where I can buy a quality tester, that has the above requirements, that can be shipped to Hong Kong I will really appreciated it. let the flames begin!:beer::mitsu: |
Bump anyone?
