-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Evo Rocker Arms - What's the deal? (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/651802-evo-rocker-arms-whats-deal.html)
R/TErnie Mar 26, 2013 09:34 PM
Since I broke a Rocker Arm in 2 pieces... I've been looking at replacing all of my rocker arms.
Seems there is some kind of a difference between 1st gen DSM's and Evo's rocker arms. Then I read about 1st genners upgrading to the Evo units. Can someone tell me what the best option is?
Babs Mar 26, 2013 09:41 PM
Supposedly the Evo rocker arms are stamped steel and weaker compared to the 1G. I haven't had any problems with mine though. What RPM are you revving to?
R/TErnie Mar 26, 2013 09:46 PM
8800 peak. Usually shift around 8400.
griceiv Mar 27, 2013 03:39 AM
are you sure you didn't just float a valve and the resulting PTV impact broke the rocker?
R/TErnie Mar 27, 2013 05:44 AM
Tough to believe I floated a valve with Kiggly springs at 8500 rpms. But... The damage looks like the valve was open when the cam wasn't... That would suggest itself to your theory.
browningderek Mar 27, 2013 09:04 AM
I just broke the roller on one of mine and killed the cam. I searched around and ending up buying 1 new OEM rocker. Hope it doesn't happen again.
mt057 Mar 27, 2013 09:18 AM
Which springs are you using?
browningderek Mar 27, 2013 12:01 PM
Buschur duel
Liqquid Mar 27, 2013 04:50 PM
what cams?
looks like R/T is using S3's?
EvoVIIIFL Mar 27, 2013 05:47 PM
Interesting. I got a friend spinning to 8500 on a 2.2 with no issues on kelford 272s.
I spun on my old 2.0 to 9k with JUN 272s no issue either. I run buschur duals and my friend beehive iirc.
I'm going to bigger cams. Hope this isnt an issue.
R/TErnie Mar 27, 2013 06:51 PM
I was about to sell my s3's and get R2's... Not sure what ill do now.
RSMike Mar 28, 2013 01:33 PM
Whats your installed spring pressure Eric?
Did you test it?
I bought the GSC 5041 kit (old one) and still needed to shim the intake 0.040" and the exhaust 0.060" to get 100lbs on the seat.
browningderek Mar 28, 2013 02:14 PM
Aaron at ER thinks it was a fluke and I will be fine with r2's and stock rockers. I got a set otw so I guess ima find out how they do! Its only 1mm more lift so how bad could it ? In all honesty I was beating the crap outta my car when the roller broke. So that's what I get I guess. Lol
