VRSF 4" intercooler is on and here's my review
Just got my 4" VRSF intercooler and Muse LICP from Tiago at VR-Speed.com today (super-fast shipment :D ) and I just mounted them a few hours ago.... I replaced my old TurboXS 3.5" tired and gunked up intercooler and my Injen LICP (FINALLY) ....let me tell you... This thing fits so nicely under the crash beam that all I had to do was slip it from under it... Without touching anything else, I went for a test drive ....my evo seems to be spooling up faster and is now peaking at an extra 1-2 psi ....this intercooler is a heavy solid piece..... I will probably need a retune, but overall I am happy with my purchase.... The only hiccup and gripe that I had, was that the supplied couplings were an inch too short on the Muse Lower-side and 3/4" too short on the Injen Upper-side ( Hey Tiago: take notes, make your silicone couplings an inch longer please :P ) ........lucky for me, I remembered I had some extra 2.5"-3.0" 45 degree silicone reducer bends laying around ....just wasted an hour trying and trying to get my pipes to line up, and another 30 mins looking for my spare couplings in the garage ... I will let you all know how my tune goes, when I get a chance to get her back on the Dyno .....thanks again to Tiago !!!
Got any photos on how it fits with the crash bar? Im in the market for a new intercooler and this looks like something I might invest in
It was getting late when I finished it but Tom I will go out and take some pics in the sunlight
Actually was looking at these VRSF intercoolers tonight. Trying to decide between the 3.5 or 4".
Glad to hear the fitment is good. What whp are you around? |
Originally Posted by 716amg55
(Post 10765731)
I don't know how spool up would have increased with a larger IC?
And a heavy intercooler isn't desirable :/ |
the heavier the core the denser it is and the better it is at doing its job
Originally Posted by ihockey1
(Post 10766480)
Density (finpack)and weight are not necessarily proportionate. Considering thickness of bar and plate plus end tank...
Pre and post iat would be interesting. |
After my install, my spool was About the same, maybe a little less. I had a stock IC before, I have the VRSF 4" now. I was able to tune the timing better too with this new IC, Im still not done with the tune thou, its been raining here and i cant seem to get some good logs done.
Originally Posted by dtrackstar
(Post 10766458)
Originally Posted by Raptord
(Post 10766529)
A denser core would slow down air more, which would slow spool, not improve it. So the question as to how it spools faster vs the previous IC is a valid one. Could have been boost leaks in the old configuration or improvement from the different LICP I suppose.
how is this 4" intercooler mounted? as i did not see any bolt holes? thanks in advance
(Post 10766480)
Best to log IAT before the throttle body and then compare to ambient temps. This is a good indicator and I strive to see within 20F of ambient, which I see using the Garrett 24"x12"x3.5" core on my EVO. |
/\/\ What he says. Thicker is not always better. Bigger thicker intercooler means spool will go down, simple physics
| All times are GMT -7. The time now is 03:34 AM. |
