Help, can't select gear right after depress clutch
Hi everyone,
I hv recently have a very weird problem, :confused: each time I want to select gear, I will need to depress my clutch pedal and hold it for one to two second, otherwise it almost impossible to shift in to any gear, I took to few work shops they all said different thing(gear box, clutch), I have recently replaced a new slave cylinder but it didnt hlep. hope anyone can give me some ideas where I should start to look at, I am currently running exedy 3 pucks ceramic clutch with stock 6 sp gear box. thanks in advance.{thumbup} |
I always replaced master/slave together in my DSM, haven't had to in my Evo yet. However, if that wasn't the issue it usually meant my clutch was bad when it would not go into gear or was very balky and particular about doing so.
adjust your clutch properly.
Originally Posted by cfdfireman1
(Post 11262307)
| All times are GMT -7. The time now is 10:27 PM. |
