-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   06 Evo won't rev help? (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/705434-06-evo-wont-rev-help.html)
French-frye Dec 28, 2014 02:58 PM
Ok like it says it won't rev under any load. Neutral I can rev to about 4-5k but in gear under load it won't go past 2 and it starts to sputter and carry on. I thought it might be plugs (since I got the car 5k miles past the plug service) so I changed them.
It happened on the highway cruisin about 65-70 and it just like lost power, and my speed started dropping, then I couldn't get any power back, I pulled over and checked what I could as far as I can tell I don't have any boost leaks, (don't have a tester but I'll be making one soon) runs fine at idle, any other opinions to try? Anyone have this happen? NO CEL though and engine running rich at idle but I have no cat. Any help would be greatly appreciated thank you!
French-frye Dec 28, 2014 05:17 PM
I've searched and read everything I could but couldn't find one with my symptoms, checked maf and for boost leaks and found nothing
Bhsj13 Dec 29, 2014 07:51 AM
bad coils, improper plug gap? maybe just a tune if you have aftermarket performance parts installed without a tune.
Ev0ikon Dec 29, 2014 09:53 AM
My lunch money is on boost leak(s).
French-frye Dec 29, 2014 03:12 PM
Ok so I decided to check some live data with the scan tool got home from work went to start it and it started then immediately stalled out, started again it idled a little bit then stalled out as I started it aThird time it finally stayed running but I held the clutch jn the whole time and my mods are an injen hard pipe kit, and a 3in turbo back exhaust, (test pipe not high flow cat) still no codes except the one I created by unplugging the maf while running to see if it made a difference, I will be going to home depot tomorrow to get stuff to make a boost leak tester, hoping it is something simple.
French-frye Dec 29, 2014 03:13 PM
Wouldnt it have misfire codes if the coils were bad? And I'm going to recheck plug gap just to be safe. And I may get a reflash. If the coils are bad I'm going to get a spoolinup COP kit
French-frye Dec 30, 2014 03:52 AM
Sorry guys my evo knowledge is limited I came from Hondas and they would only set a light if the misfire count was high as hell and steady, an intermittent misfire would not always set a light, and a bad maf would not allow it to start. I know this isn't Honda but I'm not sure on how Mitsubishi sensors are set up :/
Htcg06 Dec 31, 2014 08:12 PM
I think youve got a boost leak
Htcg06 Dec 31, 2014 08:13 PM
Or maybe the cop kit
Do you use evo scan
Peter Tiebout Jan 1, 2015 05:52 AM
look around for a hose that popped off. probably a small vac. line came off.
shavkatjon2000 Jan 1, 2015 06:52 AM
looks like a boost leak i had similar issue i thought no boost leak when i made my own boost leak tester i found the leak fixed it since then no issues
French-frye Jan 1, 2015 08:16 AM
Originally Posted by Htcg06 (Post 11368233)
Do you use evo scan
I don't know what evo scan is :/ is it a reflash for the ecu? Or just a data reader?
French-frye Jan 1, 2015 08:17 AM
I just got my pieces for a boost leak tester (had to go everywhere to find the right sized coupler but hopefully I can figure this out today and its something small. Thank you guys for the input!
ak47po Jan 1, 2015 09:28 AM
https://www.evolutionm.net/forums/ev...g-how-why.html
