oil threw oil cap
Having a problem with oil coming out threw the cap, went out the other night an did a pull an car started stuttering so pulled over to find my oil cap came off and got oil all over, so filled it back up with oil an put cap back on and drove it home, new oil cap came in and put it on felt to seal nice an tight on like the old one, went out and cruising it drives just fine but once doing a pull got the same oil all over and looks like its coming from the oil cap again? any ideas.
Originally Posted by boostedadiction
(Post 11437120)
Having a problem with oil coming out through the cap, went out the other night an did a pull an car started stuttering so pulled over to find my oil cap came off and got oil all over, so filled it back up with oil an put cap back on and drove it home, new oil cap came in and put it on felt to seal nice an tight on like the old one, went out and cruising it drives just fine but once doing a pull got the same oil all over and looks like its coming from the oil cap again? any ideas.
Maybe a crack in the valve cover..... |
appears to be from the cap, not sure how valve cover couldve jus cracked
Are you sure it's not from the dip stick tube?
(Post 11437127)
Still seems weird that oil would be pushed through the cap though. |
Dipstick tube is still down, which was the first place i checked, and i agree this is weird never had anything like it before.
My car did this on my old cap with out popping the dipstick tube. New cap solved it, but then I also did -10an vents in the valve cover because the crankcase pressure was making my turbo leak.
You probably have too much crank case pressure. |
(Post 11437164)
A catch can doesnt do anything to help with crankcase pressure issues. Grab some popcorn and start rearing here: https://www.evolutionm.net/forums/ev...re-issues.html
I see your sig mentions quest for 10's which to me means you are running a boatload of boost larger turbo or a combination of the two which all leads to increased crankcase pressure. If your motor is built and built loosely that'll also contribute to increased crankcase pressure. As such you need to help your engine breathe. |
mine oozed oil out from under the cap until i drilled and tapped the valve cover
Originally Posted by heel2toe
(Post 11437212)
^You disagree with me yet you fail to truly comprehend what I'm saying as evident by your comment...let me try again. A catch can does absolutely NOTHING to help the engine breathe better. I'm not saying that they aren't important as I think they serve a purpose if a quality can is used and they are plumbed properly. I have a saikou michi dual catch can that I think works quite well.
However, you said you disagree with my comment and then talked about how you removed your PCV installed a -10an fitting on the back of the valve cover and drilled out the side port to -10an as well. What do you think that did for you? That is what solved your crankcase pressure issues not putting a catch can inline. A catch can will not help things breathe better and technically will even be a restriction albeit hopefully negligible if plumbed properly. So as I said to the OP there is an awesome thread on this topic which he should read through and come up with a strategy to help alleviate his crankcase pressure issues. |
(Post 11437485)
yes i have an fp black on e85 etc on stock block with cams an typical set up, so you seem to think installing a catch can wont solve my problem? Then what do you think i should do?
(Post 11437212)
(Post 11437900)
