Blouch 3.0 XTR
Hi
Has their been any results on this turbo yet? I can't seem to find any on evolutionm or the MLR Thanks jamie |
Try searching the CBRD BBK-C, same turbo minus the name. Not many people ran the BBK-C if I recall.
Originally Posted by e_kobz
(Post 11579370)
Cheers for that. Why didn't many people use them. I knew their was a link between BBK and blouch but didn't know it was a similar unit |
Originally Posted by Tonks
(Post 11579373)
I knew their was a link between BBK and blouch but didn't know it was a similar unit BBK Full JB - 1.0XT BBK Full BB - 1.0XTR BBK-B - 2.0XTR BBK-C - 3.0XTR |
Thanks any reason why the C wasn't very popular? I know a people on the BBK-b who had great results but not the C
There is no technical reason
Blouch IS the manufacturer and engineer of CBRD BBK line and CBRD & Blouch never put much effort into marketing comparee to FP, And Blouch does not make any effort to sell today Fact remains BBK/Blouch wheels are lighter then FP resulting in great response almost worthy of HKS 7460. The BBK-B is impressive turbo. -C has shown few great results but at the time -C and -b were not clearly distinguished so I cannot tell what was difference, but on stroker trying -C is totally appropriate. |
How many lbs a min does the 3.0 flow?
Originally Posted by ineedboostman
(Post 11579760)
Here is information from MAP about the Blouch Dominator turbos.
Originally Posted by maperformance
(Post 11418741)
Ask and you shall receive!!!
For the Evo 8/9 Turbochargers here are the flow rates and HP Rating (Crank HP on Pump Gas). Dom 1.0XT and 1.0XTR flow 47-48lbs per min Inducer Wheel Size: 62.5mm Exducer Wheel Size: 54.3mm HP Rating: 480CHP Dom 2.0XTR flows 56-57lbs per min Inducer Wheel Size: 62.5mm Exducer Wheel Size: 54.3mm HP Rating: 570CHP Dom 3.0XTR flows 64-65 lbs per min Inducer Wheel Size: 67mm Exducer Wheel Size: 60mm HP Rating: 650CHP For the Evo 10 Turbochargers here are the flow rates and HP Rating (Crank HP on Pump Gas). Dom 1.0XT and XTR flow 47-48lbs per min Inducer Wheel Size: 62.5mm Exducer Wheel Size: 54.3mm HP Rating: 480CHP Dom 2.0XT and XTR flow 56-57lbs per min Inducer Wheel Size: 62.5mm Exducer Wheel Size: 54.3mm HP Rating: 570CHP Dom 3.0XTR flows 65-66lbs per min Inducer Wheel Size: 62.5mm Exducer Wheel Size: 54.3mm HP Rating: 660CHP We are absolutely ecstatic to carry the Blouch brand here at MAP and help them get these turbos out into your hands! |
I'd like to hear some first hand experence on this turbo as well. I remember long ago someone posted some results on the BBK-C. More examples would be nice to see.
https://www.evolutionm.net/forums/ev...r2-93-e85.html |
Originally Posted by J_Striker
(Post 11581096)
That looks like it spools like a Black, instead of a Red or Green. S0 I think it all comes down to what you're looking for. I'd prefer quicker spool, but I am sure the OP is happy with his car :)
Would be cool to the map
If it's of any interest im having on mapped next Monday. Was due last Monday but had a faulty actuator so back on the RR Monday now
(Post 11589627)
Did you have this done? If so, what were your results?
