Wideband Install
I remember reading that there is a fuse in the box that is unused, and always stays on that is perfect for plugging in a wideband. Can't find the thread again. Can anyone tell me which one it is, and what size fuse I'll need?
Anybody?
You wouldnt want the wideband ti always stay on. It has a heated element that you only want on when the car is running. Find a switched 12v circuit to tap.
(Post 11705865)
Originally Posted by ODUB
(Post 11706179)
I meant always on when the car is on. If the key is turned on, it's on and doesn't flicker on startup.
Anybody?
(Post 11705097)
On every single car I've ever worked on, I always use the ACC circuit from the radio for gauges and wide bands. ...accept one car which had a turbo timer and since I was in the ignition column anyway, that's where I tapped from, ignition switch for accessories. You have to be certain you are using a fused circuit typically 10amp for what your are using. To find a fuse location in the box from ignition cycle, use a multimeter, or one of those electrical circuit light thingys (super easy) Amperage specific for your electronics should be listed in the directions (my guess is 10) |
Originally Posted by GTijoejoe
(Post 11707217)
The term you are looking for is electrical circuit for accessories "ACC" or ignition on.
Just use a fuse tap and tap into the fuse that is used for the gauges.
bump
