What's next?
So my current mod's are
- Tubular stock frame turbo manifold - O2 dump with hood exit - 3in downpipe - 3in Test pipe out exhaust - Wally 255 - Halman boost controller - kelford 280 cams - Air intake - 4.5 garret intercooler -FIC 1250 -buschur double pumper - exedy twin disk Currently have stock intake manifold/TB and also stock uicp/BOV What should I pic up next to help make more power? |
C.O.P. Kit would be a good idea.
Stock frame turbo of some sort FP or BBK something along those lines. Port work on manifolds 65mm TB
Head studs!
Ohlins.
People throw lots of money getting power when suspension will transform the car in the corners allowing you to use some of that power you already have. |
Those are some gigantor cams, total mismatch if you're on stock turbo. I'd probably change them out for something smaller if you're not going for 500+ whp (you'll want a built motor for that). Studs, as mentioned. Bigger turbo, forged bottom end, Ohlins, all good choices.
Originally Posted by RS200
(Post 11712939)
I would honestly go with smaller cams, they would make your car feel faster, and it might actually be faster overall. I would consider 280s to be a net negative on your setup, actually - you could be giving up 30whp in the midrange, without the top end benefit. Even stock cams may be a better match.
http://dsportmag.com/the-tech/showca...final-results/ |
only way you're goign to see benefit from those cams is with a bigger turbo. 272's would be better for stock turbo
Suspension to suit the car's use, then a turbo upgrade.
(Post 11713147)
Originally Posted by llDemonll
(Post 11713164)
Originally Posted by 1SlowRS
(Post 11714935)
what if I went and add'd the atp gtx35r?
(Post 11714935)
I always wanted big power so that's the route I'd go. |
Full Replacement Short Shifter
1 Attachment(s)
Our Full Replacement Short Shifter will provide the best shifting performance possible, and seems like it would be your next ideal mod. It provides a 30% throw reduction, a 1.25" height reduction, 22% side to side reduction and is bent to sit closer to the driver seat than the OEM Shifter. Every one of our customers that has purchased this is happily satisfied with its performance and seeing as your car is already impressive with its modifications we're sure you'll love it. The FR is on sale for driving season so if you're interested, be sure to use promo code: DRIVINGSEASON
http://www.twmperformance.com/shorts...rtshifters.htm Attachment 257529 |
+1 on a short throw shifter. It was one of the first mods i did to my evo back in 2005, for me its been a mandatory mod for all the stick cars i have owned.
| All times are GMT -7. The time now is 07:15 PM. |
