grimspeed 3 port ebcs
so, i am currently routing my pipes. i have seen sooooo many different ways of routing external waste gates. my question is do i need to have a line running to my intake manifold. do i have to use my compression housing nipple, do my top ports need to vta, bottom ports to number 2 opening. i ask because i currently have
pot 3 vta port 2 bottom waste gate port 1 top waste gate with a T to intake manifold. how should they be routed? |
check with your tuner how they like it set up...
turbo smart has a good graphic of the differences i think you always pull the vacuum from the compressor housing nipple. http://www.turbosmart.com.au/wp-cont...Y_12_rev_2.pdf |
