Vented VS. Sealed Catch Can Test, which is Better? Watch to find out!
Ever wonder which catch can/breather system is better between a vented style system and a sealed style system? If so watch to find out!
Using my 9 second (best ET of 9.98@147mph) 2003 EVO 8 running 40 PSI on a Forced Performance Zero Turbo I decided to test a Saikou Michi vent to atmosphere dual catch can system, as well as a Saikou Michi sealed dual catch can system to see which was most efficient on my configuration. Disclaimer: I realize that with different variables, components, configurations the results could be different, but wanted to share my results for my particular configuration. Use the information as you see fit, and enjoy! |
Thanks for taking the time to do this and sharing it! Very informative, and I'm sure will help a lot of people!
Loving the eye candy in the engine compartment.
Thank you for taking the time to put this together Sir.
A recirculated system is my preference also for a street car. As well as a piston ring gap on the tighter side. Thats interesting that the newer FP turbo's are using the smaller .020 restrictor to further restrict the oil flow . The older ones and early HTZ use the .030. |
If you really want the best setup , you would have run it from the crank case/block. Currently the blowby has to find its way through the oil drain guides up to the head and under the valve cover before making its way out Vented or Sealed. Having a setup that also releaces the blowby directly from the crank area is best .
My Mazda CX-5 has one PCV on the valve cover and one on the block. The one on the block has a factory oem oil separator "catch can" . |
1.)I make a disclaimer several times that there are different ways to do this and get different results. 2.)this was done for general knowledge of people with similar setups or considering similar setup, not to start a debate. Use the information as you see fit. 3.)in reference to your comment, if you watch the video i clearly point out the second catch can off the PCV which remained unchanged for the test. venting off the block is really not necessary on these cars unless you have excessive blow by. You want to keep the oil in the engine and reduce pressure at the same time. I have proven this system is working efficiently at that without having to vent the block itself. Your Mazda may be different but that's a whole other application. |
Originally Posted by 0to140in9
(Post 11764914)
(Post 11764914)
Perhaps you could have created this post and closed the thread or asked a Admin to close it for you. This way no one can create a debate or comment something you wont like.
(Post 11764914)
I only mentioned the Mazda to show that OE is doing it on the block. Even my friends 99 Civic SI from back in the day I remember having it. |
Good video.
The thing here is that you're starting off with a known good engine and doing the test on it. Most people who fit catch cans do it because their engines are broken and they're fitting the catch can as a "band aid" to hide the problems. Problems as in smoke and excessive blowby. |
Originally Posted by BluEVOIX
(Post 11764925)
I got you disclaimer. So your saying your not open to healthy constructive comments ?
So did you not see the sticky right at the top regarding PCV’s , crank case pressure issues etc... instead of creating another thread ? Dont get me wrong Im happy that you shared this information and made a video clip. But your attitude sucks unfortunately. So if you didnt want comments or debates dont start a new thread for existing topics that have a sticky already. Perhaps you could have created this post and closed the thread or asked a Admin to close it for you. This way no one can create a debate or comment something you wont like. So did you monitor the the positive/negative pressures in the crank case area as well during these tests ? I only mentioned the Mazda to show that OE is doing it on the block. Even my friends 99 Civic SI from back in the day I remember having it. No need to get bent out of shape here...... |
Originally Posted by RightSaid fred
(Post 11764938)
Good video.
O.P, both ways you have posted are efficient, had same results as you have posted, I have used both, along with other different ways on 4g63 and on different applications through the years.
Another way that has the same/very similar results as the second way, is having another ventilation hole on the same side/parallel to the oem one, both enlarged, and both ventilated to atmosphere. Marios |
Question, for both of the tests did the intake manifold PCV remain the same...closed catch can between intake manifold and valve cover PCV valve? If yes, then the only change was...
1) Valve cover to closed catch can to turbo inlet 2) Valve cover to VTA catch can |
Originally Posted by 240Z TwinTurbo
(Post 11765037)
1) Valve cover to closed catch can to turbo inlet 2) Valve cover to VTA catch can yes to all your questions. |
Originally Posted by Evo8cy
(Post 11765026)
Good video. Thanks for the work.
Currently running the STM sealed system and couldn't be happier. |
