ACT Throw Out Bearing
Recently purchased an ACT ME2-HDSS clutch kit to replace my slipping Competition Clutch Stage 2. I've got the newer kit which comes with the Monoloc, glad I don't have to buy it separately. My question is, do most people use the TOB which comes with this kit, or is it better to just buy the OEM TOB? I've heard some people say that they are the same, I couldn't confirm this though, thoughts?
I bought an oem tob with my hdss clutch kit. I weigh'd the ACT and OEM tob's and the oem one weighed a little more. Had the act 6 puck prior while using the act TOB and it lasted 60, 70k miles before the TOB failed. The clutch was worn down to the rivets as well so its not like I would've gotten that much more from my clutch if the tob didn't go first.
so if no driving hard all the time the ACT tob is fine? i mean strictly DD.
My first OEM TOB was perfect at 90K, the second toast at 25. I dunno what changed or just the luck of the draw. But since I know I might only get another 25K out of the OEM part I'd not hesitate to use the one in the kit.
Originally Posted by barneyb
(Post 11778014)
Originally Posted by CaptainSquirts
(Post 11778222)
Was your clutch replaced when you changed the TOB to the one that lasted 25k? Just curious because the person that swapped my clutch said my worn clutch caused my tob to go bad.
Go oem.
Go with their tob that was most likely engineered around their clutch for fitment and other criterias... If using a stock replacement clutch then oem all the way.
So off topic question, but about 6 months ago my clutch was slipping in 4th and 5th when going WOT. Car was stored in my garage for 6 months, I ordered a clutch kit while deployed. Now when I drive the car, there is no slippage in any gear, like all is well again. Has any experienced intermittent slipping like this? I've got an appt with a local shop to have the clutch swapped (reputable shop, reasonable rates), any reason I shouldn't go ahead and go through with the swap?
Originally Posted by SW20Mike
(Post 11779763)
Ita currently a Competition stage 2, I have an Act hdss kit to put in.
(Post 11779787)
my act TOB is acting up, just making tons of chatter when off throttle.
