Drivable clutch for 475-500 WHP
I have an Evo 8, FP red otw and after tuning I should be mid to high 400's in HP. Currently still have the stock clutch (not slipping). I don't launch and have no intentions of launching. What is the best clutch out there that can handle that power and is close to stock feel?
Thanks! |
exedy twin
Originally Posted by tauro91
(Post 11800582)
exedy twin
Exedy twin is nice, the SD pedal feel is almost like stock. Although it comes with a price tag. There are affordable single disc options that can hold 350-375 WTQ that won't break the bank and are perfectly driveable. {pcfreak} |
Originally Posted by Evo9_Dubai
(Post 11800583)
It really depends on what turbo he goes for and the torque the car will be making.
Exedy twin and tripple are loud for daily drivers. I have run both and you can't press your clutch in to rev your engine without it sounding like there is something terrible off with the car. I understand that it's normal, but I need to find a clutch that holds 600ftlbs torque that's less noisy.
That being said, nothing beats the feel of this clutch. It just doesn't slip. |
Going to be running the FP red (ss) hopefully not a bad choice. Will keep torque around 375 and HP at 500.
Just get an ACT HDSS.
also, that red with the SS housing will be laggy. I’d try to find a MHI housing red. |
ACT HDSS or XTSS
I suggest running a single of some type.... act
I have had 2 twins, hd & sd pressure plates. They dont like being stuck in traffic situations in a hilly area. The thin steel plate warps quickly for me p/n PP02. Once this warps, it becomes difficult to get into gear when idling cold. the clutch just draps a bit, despite chasing the release point with the adj. rod. I will be pulling my current twin soon. |
ACT HDSS. I Have 340 torque and my last act 6 puck one lasted over 60k miles(with a nice chunk of launches, a lot of slipping my end which probably could've gotten a lot more miles out of the clutch if I didn't suck at it).
Originally Posted by Aby@MIL.SPEC
(Post 11800746)
I have had 2 twins, hd & sd pressure plates. They dont like being stuck in traffic situations in a hilly area. The thin steel plate warps quickly for me p/n PP02. Once this warps, it becomes difficult to get into gear when idling cold. the clutch just draps a bit, despite chasing the release point with the adj. rod. I will be pulling my current twin soon. I learned that for DDing a single street disk is best. For drag and track, you can't beat a twin or triple. |
For a DD car, an ACT HDSS or Comp Stage2 will be fine since you're on the stock motor and torque will be around 400 at the wheels.
I would also agree on a ME2-HDSS for a stock engine or a ME2-HDG6 6 puck if you are going to turn it up down the road. Sprung disk for a street car.
The HDSS is a single disk full face and will drive well. The ME2-HDG6 is a 6 puck and with proper break in and driving works well for a street clutch. I'm on my third replacement disk with a taller final drive its a nice clutch for an occasional launch and it shifts well. |
Me2 HDg6 gets another vote for me, rated to 675ftlb i believe, its sprung and the pedal feel isn't too bad, very usable for a DD and not as loud/irritating as a tiwn.
Thanks as always Aby for the real scoop.
Related questions to all: 1. What grease do you recommend for the splines / pivots in the tranny? Seems the urea based stuff from Honda is highly recommended. I have and was planning to use Bendix BL20. 2. What’s the best tranny fluid for those who do get after it? I’ve tried a couple, liked the Mitsubishi 6-speed stuff by far the best for shifting, but TRE recommends Motul, which I’m using. Shifting definitely got worse. I’m also visually noticing wear on 4th gear though, so it’s a trade. Installing a new HDSS next week.
(Post 11800746)
