What external wastegate dump tube for FP SS housing with FP Cast O2 Housing?
I will be upgrading to an FP Black soon, and plan on going with the SS housing paired with FP's Cast O2 housing to work with my Buschur Downpipe. I prefer to keep the O2 dump external as well.
Just wondering what you guys that are running this setup are doing for the wastegate dump tube for the Tial MVS with FP's cast O2 housing? I figured in my search for parts that FP would at least offer a dump tube to work with that setup. I do not want to have to buy an STM or MAP v-band downpipe and dump tube setup. Anyone with said setup, please feel free to let me know what you are using for the dump tube, where you got it, and if possible provide pics. Thanks in advance, Scott |
Just have someone weld up a dump tube. I believe the kit form FP comes with a spare v-band but it doesn't really matter. Get it installed and then have someone local weld one up.
Originally Posted by schuhie
(Post 11803396)
There are no shops around here that amount to crap for tig welding something up that wouldn't look like a freaking blind moron did, lol. Nor that I'd even want my car in their shop to fab up the bends for the tube :lol: I would prefer to keep the setup looking as clean as possible even if I have to contact STM or someone to get a nicely welded dump tube. |
FP has a dump tube, it comes in their bundle. You may just have to call them to get it separately. The ones I've installed, I had to add a bend to them to clear the LICP. They also come way long and need to be cut down. I had one guy want it out the hood, and it goes out the hood just fine with no bends, just have to cut it down.
cast o2 housing wont work without changing flange on downpipe and the fp housing comes with a dump tube. i have one for sale if you need one, housing and dump tube, because once i figured out i needed to change the flange on the downpipe i just ordered the stm downpipe.
I have a buschur downpipe, with 2 bolts. Will that not bolt to the fp cast housing? Looks as if it does? What dp did u have?
m2 3in downpipe. i thought it would work also until i was almost all down and ready to start went to put downpipe on and not the same size.
The buschur down pipe def won't work, it doesn't even use the stock donut gasket. The FP O2 housing comes with a new flange to weld onto the DP though.
(Post 11803542)
Ah someone must have welded something on mine then..it was on the car when I got it and I've been using the epm o2 dump with a factory donut gasket for years. I'll look to see if someone has done some welding on it. |
Yup it appears it has the exact same flange that fp sells on it, which is the Works exhaust flange.
So this cast 02 housing should bolt up just fine for me. I do see they offer the dump tube in that bundle now. |
