4WD not engaging
I experienced a few months ago that all 3 ACD lights came on. No codes.
AWD still worked fine, now suddenly the AWD is not engaging. I floor it in 2nd or 3rd i get crazy Honda like wheel spin. I am suspecting a failed ACD pump. Other than that it drives fine. Can i check the ACD codes through Evoscan 2.9 for evo7/8? What things do i look for to determine the cause ? Thanks. |
Does the pump turn on when you start the car? Do you still have 3 ACD lights lit?
Originally Posted by mines5
(Post 11808942)
Originally Posted by V.8MR
(Post 11809002)
Originally Posted by Teal2nnr
(Post 11809025)
Are you spinning or is your clutch slipping? I've ran pretty big power with a failed ACD pump and i don't notice any issues when driving in a straight line an pinning it. Its a different story if you're at the track taking corners though..
confusing me. The key thing i noted is that when climbing i floor it from 5k to redline it doesnt sleep but wheel spins. Any Hard ware checks that i need to look at ? |
UPDATE*
So finally checked the ACD pump , its oil pressure sensor wasnt working properly. Replaced it and the ACD lights went back to normal. 4WD started working normal. The bad news is the 6 leg Quarter master is slipping like oil. Not a single Launch on this clutch . Using it since 2015. Any suggestions ? |
(Post 11809025)
575 WHP on 93 Octane. Yeah all 3 lights were on when it stopped working.
What a strange occurrence. Glad you have resolved it. As for the clutch, I would go with the ACT Xtreme Sprung 6 puck (ME2-XTG6) for cheaper, quieter ride. Or you could be unreasonable like me and get a noisy Exedy triple disk. The exedy will never slip on you, but for your current power levels, a twin might be enough.
My next clutch is likely going to be the ME2-XTG6, because it's really all I needed in the first place. I don't launch often enough for the triple. |
Originally Posted by Pal215
(Post 11809688)
My next clutch is likely going to be the ME2-XTG6, because it's really all I needed in the first place. I don't launch often enough for the triple. I am also Considering EXEDY TWIN but still not sure which version to choose. |
How exactly would the AWD stop working? Just curious...
^Lol hey Pete didn't know you were still on here...I think AWD shuts off when VTEC kicks in but im not sure.
On a serious note, now that you mentioned your clutch was slipping were you sure what you were experiencing was indeed wheel spin? The easy way to tell is when you get on it if the RPMs and MPH goes up then wheels are spinning RPM and no MPH its clutch slipping. A failed ACD pump will keep the center diff open. So technically your car is still AWD at that point but its only powering whichever side is easier to spin. |
Originally Posted by grillpt
(Post 11809866)
confirmed that only the front wheels are wheel spinning. 2nd and 3rd gear same situation. I also noticed it started running very light unlike 4wd drive behavior. After ACD issue was resolved it was back to normal. |
It doesn't stop being AWD because ACD stops working. It amazes me how little some people know about the cars they own.
Originally Posted by razorlab
(Post 11810016)
Can you please share what can it be ? |
