Walbro 525lph Gas/E85 in tank pump
This is a very powerful pump that Walbro / TI Automotive has developed supporting more than 800 whp. Could this be the pump that retires hobbs switch based double pumpers for the majority of us? Any experiences with it?
Has anybody installed this pump into an evo 8/9 fuel pump housing and does it go in the same way as the Walbro 450? The specs imply it should. Finally, was it really initially developed for the Hellcat? https://cimg7.ibsrv.net/gimg/www.evo...156c29fde8.png Just when you think they're done, they've only just begun. |
damn nice find! its shorter too which should make for an even easier install. Your still going to need the hobb switch activated harness because there is no way the OEM wires are going to feed this.
There was a decent writeup on Radium's website comparing the new 525 to the older 400 pump. See here: http://www.radiumauto.com/Blog/Post/...-F90000285-109
Taken from the article I think this sums it up perfectly "Our data shows us that the F90000285 pump flows 8% more than the F90000274 pump, but in order for that to happen, it has to draw 15% more current. So it is essentially the same pump, but using more current to drive the electric motor harder" So take that for what its worth. Could it replace a double pumper with 2x 400 pumps perhaps? I guess its similiar to when the 400 first came out and people were saying wahoo no more double pumper with 2x 255s. Regardless upgraded wiring will need to be taken into account for sure with this pump for it to flow what it claims it can do on paper. |
(Post 11834603)
Originally Posted by heel2toe
(Post 11834607)
Taken from the article I think this sums it up perfectly "Our data shows us that the F90000285 pump flows 8% more than the F90000274 pump, but in order for that to happen, it has to draw 15% more current. So it is essentially the same pump, but using more current to drive the electric motor harder" So take that for what its worth. Could it replace a double pumper with 2x 400 pumps perhaps? I guess its similiar to when the 400 first came out and people were saying wahoo no more double pumper with 2x 255s. Regardless upgraded wiring will need to be taken into account for sure with this pump for it to flow what it claims it can do on paper. Very good info here. I suppose the only way around that is to do the STM relay hardwire kit with low gauge wire. Based on Radium Engineering's research, this is a pump that if you have a walbro 450, and you're just shy of meeting your hp goals, this is the pump to toss in the tank next. There's only so much more flow they can extract from a pump with about the same form factor as it's predecessor. |
The new Hellcat pump is the same size as the 450. It does flow alot more.. Like any larger fuel pump it needs to have the correct wiring to go with it to deal with the voltage requirements. Now, if you were close or just wanted to extend your fuel system you could also wire in a Boost a pump or JMS voltage booster. Any pump is going to increase output with more voltage going to it. People have been using them for years without any adverse effects. I've used them on a few cars and they've worked well. http://kennebell.net/products/accessories/boost-a-pump/ http://www.jmschip.com/fuelmax-fuel-...ltage-booster/ http://kennebell.net/tech/fuel-tech/...ion-explained/ https://cimg9.ibsrv.net/gimg/www.evo...3f1ef9f43.jpeg |
also... the stock siphon may not take that much return flow...
Originally Posted by hutch959
(Post 11834634)
I see. So there will be a point where even the drilled out siphons will not be enough to handle the return. Someone with CAD software should 3d print a new, larger outlet siphon that handles increased fuel return flow, doesn't ove run the stock FPR, and keeps the siphon effect. If I upgrade my turbo one day, i'll definitely be trying a boost a pump. |
im sure a drilled one would handle it.
but the last one i had drilled, never seemed to consistently keep the tank even... the fuel gauge was always acting funny. |
Originally Posted by Pal215
(Post 11834704)
https://www.radiumauto.com/Assets/Ve....png?ts=090716 |
I wish people would stop calling these 525lph pumps. They flow 524 at 16psi which is basically *never*.
It would be like calling the F90000274 a 490lph pump, which it isn't ever in it's operational range on our cars. Please at least baseline quote their LPH at 43psi: F90000274: 422lph F90000285: 459lph Which means you are getting 37lph (8%) more flow at idle with the F90000285 over the F90000274. Just so happens it's 8% more flow all the way up to 95psi as well. |
So what’s the general consensus on this pump? Yay or nay? Anyone in here has any actual experience using the 525 pump? |
Originally Posted by 2rbolag
(Post 11845634)
So what’s the general consensus on this pump? Yay or nay? Anyone in here has any actual experience using the 525 pump? This pump is for those who have already maxed out their walbro 450's and need 8% more flow to achieve their goals without having to switch to a double pumper and hobbs switch (about 700whp). This pump will consume more current than a Walbro 450. Yay if you have are hardwire kit and a drilled siphon already and you want it to get it over with. Nay if you already have a walbro 450 and don't need an extra 8% more flow or have nothing wrong with your current setup. |
(Post 11834603)
Originally Posted by 2006EvoIXer
(Post 11845672)
You can skip the hobb switch if you install your parallel power source by copying FP relays 2 and 3. {thumbup}
(Post 11845677)
You end up with a reverse feed problem holding them open. Hobbs switch is just the easiest way to do it. There are other ways, but they are more complicated. To be clear though, you do end up paralleling the hobbs switch controlled relay with the factory stuff.
It sits for weeks at a time (good thing I have a regular full size battery).{thumbup} |
