Modify Evo 9 Turbo or Evo 6 Turbo with Garett components
Hi
I have been looking for options to upgrade my turbo. I have an evo 6 running a evo 9 turbo. I still have the evo 6 turbo charger. If I had the money I would get the FP Green, but the import tax is huge so im looking for alternative. Mods: 2.0L 1000 injectors programmable ecu full upgrade exhaust evo 9 turbo forged rods, pistons, main bearing, rod bearing 272 cams (GT) arp head/main bolts/studs thicker head gasket (Cosworth) Upgraded fuel rail and 255 fuel pump Running E85. I guess im around 420hp now My goal is 500-550 hp with plenty of mid-range power for street use. I contacted a local turbo shop (in Thailand) and asked what my options are. Their suggestion is to "You can use your existing 9 housing, it is bigger than EVO 6. I can supply you the Garrett Core with Evo 9 compressor and turbine housing." - he's referring to GT3076R components I am in Thailand, turbos are more expensive here. The price for this he's quoting is $1100 and says I don't need to modify manifold or anything. I was also looking at GT26-660, to buy the full unit. I guess I can't modify my Evo 9 turbo with housing with that, but what about Evo 6 turbo which I still have? Could I modify either for GT26-660. Or should I buy the GT26-660 full unit and install that. If so, what other stuff do I need like manifold or waste gate? Please can you give some thoughts on what I should get, considering performance and price and reliability. Thanks Thanks |
I am not much help here, but from what I know, the GT3076R is a disappointment if you think it'll be a good spooler because it is mismatched. Otherwise, Garrett stuff is usually pretty solid.
Originally Posted by ThaiEvo666
(Post 11836411)
Hi
So here in Thailand we only get Garett and Precision stuff.
I have both an evo 6 turbo and evo 9 turbo I want around 500hp (E85) focus on midrange power, quick spool etc What can I do? Modify my evo 6 or 9 charger? if so with what? Or do I buy a small Garett turbo and pay out for manifold etc |
Yes you can build ur existing turbo you can get a tdo6Hr 67x58mm turbine shaft from kinugawa and get a gt 3076R 11 blades billet comp wheel from them too this would get you between 500-550whp turbo on e85 you will need a good machine shop to do the housing job for bigger wheels without cracking them. this turbo will be bigger then an fp red |
(Post 11836411)
Hi
I have been looking for options to upgrade my turbo. I have an evo 6 running a evo 9 turbo. I still have the evo 6 turbo charger. If I had the money I would get the FP Green, but the import tax is huge so im looking for alternative. Mods: 2.0L 1000 injectors programmable ecu full upgrade exhaust evo 9 turbo forged rods, pistons, main bearing, rod bearing 272 cams (GT) arp head/main bolts/studs thicker head gasket (Cosworth) Upgraded fuel rail and 255 fuel pump Running E85. I guess im around 420hp now My goal is 500-550 hp with plenty of mid-range power for street use. I contacted a local turbo shop (in Thailand) and asked what my options are. Their suggestion is to "You can use your existing 9 housing, it is bigger than EVO 6. I can supply you the Garrett Core with Evo 9 compressor and turbine housing." - he's referring to GT3076R components I am in Thailand, turbos are more expensive here. The price for this he's quoting is $1100 and says I don't need to modify manifold or anything. I was also looking at GT26-660, to buy the full unit. I guess I can't modify my Evo 9 turbo with housing with that, but what about Evo 6 turbo which I still have? Could I modify either for GT26-660. Or should I buy the GT26-660 full unit and install that. If so, what other stuff do I need like manifold or waste gate? Please can you give some thoughts on what I should get, considering performance and price and reliability. Thanks Thanks You cannot use the garrett chra assembly and wheels with your oem evo compressor and exhaust housings. The housings are bolted to the garrett core, while on the oem chra they are on a v-band clamp connection and spring ring respectively. Also the garrett gt3076r wheels are normal rotation, the oem ones are reverse rotation, and so are the housings. The other issue is, if you buy bigger reverse rotation wheels and have the housings machined to fit the new wheels, the existing oem internals of the chra will not be able to handle the extra thrusting loading, and the turbo will fail. You need to buy whatever wheels sizes you want and have them built the turbo with heavy duty components, and convert it to 360 thrust. I personally build my own turbos, I machine and port the housings also, in fact I'm working on an experimental modification on the oem chra backplate which will help the air distribution, velocity and speed, and amplify the properties of the exducer. Not finished and put aside at the moment, but will continue on it at some point in the future. Check out MAMBA Turbochargers and related components for anything you need. Marios |
I am confused
This is what he is suggesting... "you are using stock exhaust manifold, which is reverse rotation. To use GT3076 ball bearing, you need to modify quite a lot such as changing new exhaust manifold or header, all the inlet/outlet pipe. To make think easier for 500 hp power, I can suggest that we can change Garrett GTX3076 Core and put into the existing compressor and turbine housing. Then, you don’t have to change any piping or manifold except oil inlet, water inlet / outlet only." So this is a bad idea/can't be done? |
He also says "Yes, I have a few EVO car running in circuit racing. Using the upgrade Garrett ball bearing Core in the original EVO9 housing doing 540 whp at 2.2 bar. The turbo spool very fast in EVO 9 turbine housing."
Im confused! |
(Post 11836874)
I am confused
This is what he is suggesting... "you are using stock exhaust manifold, which is reverse rotation. To use GT3076 ball bearing, you need to modify quite a lot such as changing new exhaust manifold or header, all the inlet/outlet pipe. To make think easier for 500 hp power, I can suggest that we can change Garrett GTX3076 Core and put into the existing compressor and turbine housing. Then, you don’t have to change any piping or manifold except oil inlet, water inlet / outlet only." So this is a bad idea/can't be done? Forget what he is suggesting , he is ignorant and wrong. Exhaust manifold, which ever type, has nothing to do with the rotation way of the turbocharger's rotating assembly, it only has to do with the turbine housing you are using, and the size of the turbo in relation to the rest of the engine setup. You cannot use the garrett gtx3076r chra with the the stock oem housings. You need to buy reverse rotation wheels and heavy duty chra components, have the housings machined and build a bigger oem stock frame turbo, or go to a shop that know what they are doing. Marios |
Originally Posted by Evo8cy
(Post 11836883)
You cannot use the garrett gtx3076r chra with the the stock oem housings. You need to buy reverse rotation wheels and heavy duty chra components, have the housings machined and build a bigger oem stock frame turbo, or go to a shop that know what they are doing. Marios isn't gtx3076R a reverse rotation "R" at the end? You are saying it can't go into the stock Evo 9 turbo housing as its not strong enough basically? |
(Post 11836946)
He said that about the manifold because I was also looking at buying a completely different turbo which would need new manifold.
isn't gtx3076R a reverse rotation "R" at the end? You are saying it can't go into the stock Evo 9 turbo housing as its not strong enough basically? Stating that an exhaust manifold has to do with way of rotation of a turbo is wrong, no matter any other reason he suggested a new manifold. The "R" in garrett turbo naming, means "racing". No, I am saying that the garrett chra cannot be mated to the oem mitsi housings, because garrett uses a different way of attaching their chra to their housings than what mitsubishi does. It has nothing to do with longevity and strength of the chra. You will need though to build the oem evo 9 chra with stronger internals, if you want the turbo to last on the new bigger wheels. To make things as simple as possible, forget the garrett core, you cannot put it into the oem housings, wheels are also the wrong rotation, build your evo 9 turbo with ugraded chra components, buy bigger reverse rotation wheels, machine the evo 9 housings for bigger wheels. Marios |
(Post 11836974)
No, I am saying that the garrett chra cannot be mated to the oem mitsi housings, because garrett uses a different way of attaching their chra to their housings than what mitsubishi does. It has nothing to do with longevity and strength of the chra. You will need though to build the oem evo 9 chra with stronger internals, if you want the turbo to last on the new bigger wheels. To make things as simple as possible, forget the garrett core, you cannot put it into the oem housings, wheels are also the wrong rotation, build your evo 9 turbo with ugraded chra components, buy bigger reverse rotation wheels, machine the evo 9 housings for bigger wheels. Marios This is what he is saying "don’t confuse Center housing rotation assembly or CHRA is the same meaning as Core. We will remove EVO 9 stock CHRA and replace with Garrett GTX3076R CHRA but some modification and machining need to be done." he's talking about reverse rotation Garett GTX3076R Also he's recommending " Garrett intercooler, size 12” x 18” x 3”" |
(Post 11837474)
"don’t confuse Center housing rotation assembly or CHRA is the same meaning as Core. We will remove EVO 9 stock CHRA and replace with Garrett GTX3076R CHRA but some modification and machining need to be done." he's talking about reverse rotation Garett GTX3076R Also he's recommending " Garrett intercooler, size 12” x 18” x 3”" Go to another shop, he is talking crap, chra and core is the same thing. A chra is the housing with its internals, either ball bearing or journal bearing, and the wheels, that's why it is called chra, the center housing with its rotating assembly. Now if he is referring to just the internal components, the bearing system parts, then he should say the bearing system parts and not core.Secondly, the garrett journal bearing system does not fit in the mitsubishi center housing, as this is what he is telling you basically, because the journal bearing system of the garrett chra is made for standard rotation wheels not reverse, and it also has other differences in its parts, such as the thrust bearing spacer and collar, and he will gain nothing even if there was a way to modify the oem center housing to fit the garrett journal bearing system. If he is referring to the garrett ball bearing system, again it does not fit, and the mitsubishi center housing cannot be modified in a way so to accept it, he needs to have a ball bearing system made especially for the mitsubishi center housing. Now if he is thinking of getting a brand new gen 2 reverse rotation ball bearing CHRA with wheels from Garrett and he believes he can mate the mitsubishi housings on that, tell him he can forget it, as the garrett housings are bolted on the garrett chra, where the mitsubishi ones are joined on it with a spring and v band respectively, I've already said this on a previous post, there are also other differences. Intercooler size depends on what turbo size and power you will be running. Marios |
