Evo 9 mr transmission upgrade routes?
hello all!
initially i was going to send in my trans to shep and have them rebuild and do a 5sp conversion. After a few email exchanges turns out i was confused(maybe the wording was off on their site as well) and that i could only get my 6sp rebuilt and the only way to do a 5sp conversion was to buy a used 5speed and rebuild it or buy a new 5sp. I want to ask what you guys have done? If i have my current 5 speed rebuilt will it be just as weak as it would be brand new? I will only be using my car for the streets, no plans to be launching the car, no tracking. Only intend to make 5XXwhp max. Sitting at 370whp right now but who knows how ill feel in the future. 6sp seems to be fine right now but grinds in 4th sometimes. Not sure if its due to clutch and it locking out sometime or bad synchro/gears. Suggestions? |
Having it rebuilt won't make it any stronger. They seem to not like much more than 400ish wtq, and heat from road racing. Sounds like you should be fine with a refreshed 6 speed.
If you want a 5 speed, I suggest go to Jon at TRE if you want the best trans available for your evo. |
I agree w/Sean, a quality rebuild / refresh would do you well. Im still running a full stock 5 speed (ACT clutch) which has seen a large number of track day sessions
BTW, good to have you on the boards :beer: |
I agree with the two gentlemen above. Now if you must keep your 6 speed, there is a strengthening option which can be found here:
https://www.jackstransmissions.com/c...-trans-service With that in mind, I wouldn't push it past 550trq. |
Rebuild the MR
I had a 500+whp car recently that I was doing work on for a friend, he's making 650whp on race gas and hasn't had issues yet the 6-speed is SO MUCH NICER to shift than the 5 speed. it's smooth and how a transmission should feel. the 5 speed is stronger but honestly sucks for driving "feel" in a non-racecar |
The 6spd is a better trans, but they are torque limited to about 350ftlbs. The bummer is they are so expensive to have even an oem rebuild done. I'm currently putting in a 5spd until I can afford to upgrade my 6. I say use yours until breaks, then swap. No sense in additional work, if you don't have to, especially at your power level. |
Originally Posted by llDemonll
(Post 11838893)
Rebuild the MR
I had a 500+whp car recently that I was doing work on for a friend, he's making 650whp on race gas and hasn't had issues yet the 6-speed is SO MUCH NICER to shift than the 5 speed. it's smooth and how a transmission should feel. the 5 speed is stronger but honestly sucks for driving "feel" in a non-racecar however, the 5 speed in my car now is a stage 2 jacks with all the extras... and wow.. by far the best shifting car ive ever driven.... , this tranny shifts incredible. |
(Post 11838886)
If you want a 5 speed, I suggest go to Jon at TRE if you want the best trans available for your evo. but yeah, dont plan to make more than 5xxwhp. so an oem 6sp rebuild it is? dunno how my wife would feel about a $3500 6sp strengthening lol |
(Post 11838893)
Rebuild the MR
You’ll get 10 different opinions. If you don’t want to keep rebuilding the 6th speed get the 5 speed. Shep will return your calls and deliver a unit when he says. TRE on the other hand, good luck getting him to do anything. |
Originally Posted by boostedwrx
(Post 11838951)
Feelin like i should return my mr and get a gsr lol |
Originally Posted by twinkie_mayne
(Post 11838959)
Feelin like i should return my mr and get a gsr lol Youll be fine! |
(Post 11838951)
(Post 11838954)
If i had the patience / time, I would certainly choose TRE, but its clear that they have a full customer base & are not that interested in bringing more business than they can handle.
(Post 11838983)
I took my 6 speed out at 13k miles for a 5 speed. It’s still sitting on garage floor and can turn back into an “MR” whenever ;) Youll be fine! |
(Post 11838914)
dunno how my wife would feel about a $3500 6sp strengthening lol Not to derail this thread, but a simple savings account will NEVER last. Residual income is the key to a good retirement. |
