Evo 8 idle problems/smoking powerless
watched the forums a long time now just joined now that I own an evo here is my problem I was driving car stalled on its own fought to start it got it running ish problem was couldn’t get above 2000 rpms and couldn’t get above 20mph full throttle. Got home tried to start the following day won’t idle on its own can’t rev even above 1000 rpm smokes like crazy from exhaust and I have oil misting from exhaust basically no power did a compression test and came back 165 across the board please help guys I’m so lost |
Have you tried checking the turbo for any leaks? Might have a blown off intercooler pipe some where (boostleak test)..if all checks out you might want to consider doing a leak down test.
Welcome. Thanks for joining us on the EvOM boards. Give us some background details so the guys can help out
Put all new ic piping in a whole new turbo kit did leak down test already I’m just scratching my head at it
But i have the precision turbo 6766 top mount turbo kit from map turbo smart hyper gate 45 wastegate, mishimoto radiator, mishimoto intercooler, hks272 cams his timing gears his head gasket new plugs wires, there’s more I’m sure that’s not coming to mind atm again guys any help is appreciated you guys are the best around like I stated been watching forums for years now an have used it to fix my base lancer and the current evo y’all are always my go to had to edit forgot to add that I’m at about 181000 miles on the clock |
Is it throwing any codes?
"oil misting from exhaust"
out the back? or at the header?? boost leak test pass? |
No codes and leak down passed I have exhaust cut down and running straight out the hood vent atm and it’s misting the windshield with oil when I do get it to run the third cylinder spark plug has oil on it just seen that today is it at all possible that I jumped time? I’m so lost and don’t know where to begin |
