Help! I have a wierd turbo not on the lists and the seals are shot
Hi guys, my evo is producing whiteish blue smoke only when its on boost and usually once its warmed up and been boosted a couple of times it clears up. Ive been told by local chaps this means the turbo seals are likely shot...no big deal...however, my jdm evo ix mr has a different serial nr to all the other evos on the rebuild lists.
49378-01600 Td05hra-155g6c-10.5T Any help to confirm which rebuild kit would be correct would be appreciated |
I think all TD05 rebuild kits should work. Are you rebuilding it yourself? If you are, be careful not to mess up your balance when reassembling.
