6 speed housing crack around clutch fork pivot
Got this 6 speed in today... Car had really worn clutch that went to the floor on the second test drive... Took it apart and found this:
https://cimg0.ibsrv.net/gimg/www.evo...2b9ef938c5.jpg Part fo the housing that holds the clutch fork pivot broke off... Scratching our heads on how to fix it right now.. :( |
Originally Posted by kikiturbo
(Post 11864954)
Part fo the housing that holds the clutch fork pivot broke off... Scratching our heads on how to fix it right now.. :( Eitherway, if the internals are still good inside the trans, just find a new case(front half). Or, 5 speed swap to the better gearbox. |
no, it broke before we took the trans off.. I could see the spring hanging from the access hole.... We actually had to unbolt the clutch cover and then cut the retainer off from the clutch disc side..
(Post 11864960)
well, sometimes the TOB will get stuck and in those cases we will unbolt the clutch cover.. that is normal.. Broken gearbox casing is another matter.. :D
(Post 11864960)
I guess i didn't think about trying to release it with the part that hold the fork broken off. Just saw half the collar on the TOB and knew it didn't look right. The only proper fix that i see is getting a new front half of the case. |
we did try but the TOB collar looked messed up too..
I have a spare 6 spd box that I can use or we will get a new case. We are also investigating another option of fixing it but that will require some precise machinig.. |
(Post 11864968)
I have two broken 6spds sitting in my driveway. Both have good cases. Free ,if you are ever in Central Kalifornia!
:lol: |
Originally Posted by kaj
(Post 11864996)
:lol: |
If I have time, I could. I'm 80% school, 10% family, 10% dogs now until June. I plan to pull them both apart to scavenge the hardware, anyway.
Originally Posted by Pal215
(Post 11864998)
Do I see a trans autopsy video/ picture thread in the future? :beer: Would love a How To take apart 6 speed thread :D
(Post 11864996)
:lol: |
(Post 11864996)
:lol: |
Originally Posted by Fox_IX
(Post 11865064)
Wait for real? Bro I'd totally pick one of those up. I'm in Santa Cruz
