Can’t Shift Into 1st 3rd or 5th
I was driving in 2nd gear today when all of a sudden I couldn’t shift into 3rd unless I put it back in neutral, back to 2nd, then 3rd. I parked and with the engine running and the clutch in from neutral, I couldn’t shift into 1st 3rd or 5th. As soon as I put it in 2nd 4th or 6th I was able to as long as the clutch was pushed in the whole time. If I let go of the clutch and put it in neutral, I can’t put it in 1 3 or 5 again unless I put it in another gear first.
1 Attachment(s)
How fresh is that clutch? Ive linked up the full clutch pedal adjustment for your review. Maybe its out of adjustment making gear engagement difficult
Hopefully its not the Syncros (after-all it is the 6 speed trans) Just a thought! |
(Post 11868381)
Sounds like a bent shift fork.
Free checks would be to confirm the cables, shifter, and shift assly on the trans are all lined up, tight, etc.
Based on that video, my bet is something with the cables. I would do what Kaj said first. Simple and free, can't go wrong.
Originally Posted by kaj
(Post 11868431)
Originally Posted by USMC Brad
(Post 11868497)
I checked the cables and one of them going under the intake manifold looks like it has the rubber coming off of it. Other than that they seem fine. How do I go about checking the shift assembly on the trans?
It sounds like something is out of place and moving the shifter down (gears 2, 4, and reverse) temporarily puts it back. I could give better hints if I could remember which cable moves the assly in which direction LOL |
