Whining noise whilst spooling
Hi all,
I am new to this forum and am just after a bit of advice as not a lot of people I know have experience with evos. I got mine in November last year and its been fine, until the other day randomly I developed a whining noise when the turbo is spoiling - also doesn't pull as well as before. Lets say about a 15% reduction of what it is normally like. I'm getting mixed opinions of boost leak, turbo is going etc. There is no smoke or smell - but I have had a look at the turbo and it seems to have about 2mm play which I read is not good. Can anyone offer a bit of advice of what they think it could be/to look for? Sorry I am a bit useless and don't know much! Thanks! |
Sounds like a boost leak.
Should always check that first. Are the blades contacting the housing? |
There is some wear where it looks like the blades are contacting the housing, but it doesn't look fresh - not sure how much difference that makes.
Hello / Welcome aboard the boards @Evo8_Jess
As noted, a boost leak test is in order as well as confirming the shaft play in the turbo (possible worn shaft bearings) Cheers, :beer: |
Pull off turbo intake hose/pipe from MAF and check turbo wheel for play. If you have any play, get turbo rebuilt or swap to another.
That being said, there is a limit. 2mm is excessive. Have someone rev the engine while you listen under the hood to see where the sound is coming from. Bad journal bearing turbos can sound like a kazoo. |
Glitched post
(Post 11876850)
You do realize that all turbos have play, correct?
That being said, there is a limit. 2mm is excessive. Have someone rev the engine while you listen under the hood to see where the sound is coming from. Bad journal bearing turbos can sound like a kazoo. Yes Sean, all turbos have a tiny amount of play. I kept it simple for OP. I assumed he had a stock journal bearing turbo. If I feel 0.5mm of in/out play, I will rebuild because thrust plate is starting to wear. As for 2mm, that's about the limit for ballbearing turbos. Here's a journal bearing turbo with about 2 mm of play. Notice how the exducer made contact with the cover? https://cimg7.ibsrv.net/gimg/www.evo...f058456b4a.jpghttps://cimg9.ibsrv.net/gimg/www.evo...2e0a01d294.jpg |
Originally Posted by Evo8_Jess
(Post 11876791)
Hi all,
I am new to this forum and am just after a bit of advice as not a lot of people I know have experience with evos. I got mine in November last year and its been fine, until the other day randomly I developed a whining noise when the turbo is spoiling - also doesn't pull as well as before. Lets say about a 15% reduction of what it is normally like. I'm getting mixed opinions of boost leak, turbo is going etc. There is no smoke or smell - but I have had a look at the turbo and it seems to have about 2mm play which I read is not good. Can anyone offer a bit of advice of what they think it could be/to look for? Sorry I am a bit useless and don't know much! Thanks! Also, once JB turbo is rebuilt with new thrust plate and collars, my turbos have zero play. If I put my weight into it, the entire turbo will move when I push, pull, and force wheel sideways. That's my experience with rebuilding turbos. Let's not get into another pissing match because I have plent of turbos at home and don't want to waste my time recording and uploading. |
If you truly have zero/immeasurable play, they're not going to last very long as there will insufficient clearance for oil to enter the bearing.
