Tcase rebuilt?
Hey pepps i had started a post about my back wheels not spinning at the dyno. I found out it was the tcase. I finally dropped it. I open up the tcase and the pinion has all the teeth broken. I called to take it and the charge me $1500. Bit to much if you ask me. So like i said i checkes everything looks good but the pinion. I was wondering if i can just change that and put back together and it will be good to go. No need or adjustment and non of that? Bevause that is what i heard. If it not adjusted it can whine. Is that true? Or just buy the pinion new and well wash everything and put back together.
https://cimg0.ibsrv.net/gimg/www.evo...8805b8d589.png https://cimg5.ibsrv.net/gimg/www.evo...0969fd78dd.png https://cimg9.ibsrv.net/gimg/www.evo...6d07a99e80.jpg |
Based on that level of failure, i would think a full dis-assembly would be in order. @evoholic3088
From what i can see the Mitsu service manual does not go into that level of disassembly of the T-Case. It only shows the seal replacement procedure The T-case IMO, is like a Swiss watch & your best bet is to have it rebuilt by Jacks / TRE |
That transfercase needs a complete rebuild- New Gear set, all bearings, etc.
Send it to TRE and get it done correctly. $1500 is not "too much". You should literally be expecting to spend about that. |
Agreed, $1500 is actually on the lower end for a TC rebuild. Luckily you pulled it yourself and didn't pay extra for that. Usually what happens is there is a base price and then once they inspect it they find everything else that broke or is missing and add to the cost. I'd keep 2500 cash around before you send out the TC to be safe. Same goes for transmissions and rear diffs.
Itll be north of 1500 if the front diff is damaged, probably a little over a thousand if not. I don't know how your tcase got to that level of destruction without anyone hearing/feeling anything....
Originally Posted by CaptainSquirts
(Post 11879325)
All it takes is for someone to buy an evo who is unfamiliar with how it is supposed to sound and then go online and read one of those posts that say something like "Evos are noisy cars and just make all kinds of noises naturally" to just completely ignore the problem and obliterate the drivetrain. :lol: :lol:
I have this crazy theory that the quieter your drivetrain is, the more correctly meshed and correctly broken in your gears are. Even crazier? I believe that any oem style transmission, diff, or TC part should sound only as loud as when the car was built new. If it sounds any different than that, i'd be concerned. Clutches are neither here nor there. |
Thanks guy ill send it in. Im in california dont. 3 places near me are know for evo stuff Road Race Engineering, Tunning Technology, 51/50 and JPR but last two from what i heard not to reliable. RRE told me 1600 with stronger ring and pinion and that if the housing ita crack they will replace it at no cost because they have tcase there just laying around.
About how it happened. Not sure i got car 3 years ago. But everything was apart in trunk in boxes/crates. I never checked the tcse if it was good or bad i just wanted to have it running. Never heard a pop or nothing so my guess is that it was bad already when i got the car. Tcase oil would come out good. So never ewally checked that |
Originally Posted by evoholic3088
(Post 11879336)
About how it happened. Not sure i got car 3 years ago. But everything was apart in trunk in boxes/crates. I never checked the tcse if it was good or bad i just wanted to have it running. Never heard a pop or nothing so my guess is that it was bad already when i got the car. Tcase oil would come out good. So never ewally checked that Hmm, I wonder what gear set RRE uses for it to be a stronger ring and pinion. Everybody has their secret sauce. |
OP, send the tcase to TRE if you want to know it's done correctly and comes back to you better than a brand new part from the dealer. |
(Post 11879337)
(Post 11879338)
The same Chinese gearset that Jack's and Shep offers most likely.
Yeah it makes me curious about what's out there. Maybe using crankshaft materials to build the ring and pinion gears would make them last longer. Jacks says that their gear set is a billet one. They had an "indestructible transfer case" package but it looks like they renamed it to "Performance Plus 'Adamantine' T-Case Build Service"
I wonder if someone broke it :lol: |
I thought they all used OEM ring and pinions. Just checked their websites and they say "OEM Ring and Pinion Gear Set" which would mean they use the same ring and pinion, right?
Jon also sets up the contact pattern specifically for the cars use. A drag doesn't no get the same setup as a road course car, which doesn't get the same as a pure street car, etc...
Mine from TRE in the invoice said "detailed and shot peened, EVO-7/9, CT9A". Wonder if the "detailed" means the "Gear Detailing" where they round the edges of the gear.
TRE has cars running 8's on the stock gears so I think with proper build up OEM is fine for 99% of cars until you need something custom to break the pinion shaft trying to run 7's. |
I bet there's some dude out there somewhere that is not even on this forum who just has it down better than all of us. He probably has a large successful machine shop with the most advanced tools and equipment and just buys whatever car he wants and immediately over-builds the entire drive line out of exotic and rare materials so that he doesn't have to deal with issues like this. If he is reading this, he's laughing at us right now.
