Timing Belt Kits Available @ Boostin Performance
https://c1.staticflickr.com/4/3818/3...87e5fd2f_b.jpg
Keep your engine running strong by ensuring you're on top of your maintenance routine. Over time, timing belts wear out, causing the crankshaft to lose sync with the camshaft and the valves. If timing components break, it can severely damage your engine, becoming an extremely costly repair! Save yourself the headache and ensure that your engine will be running properly with a Boostin Performance Timing Belt Kit! Contact us or visit our website to order your BP Timing Belt Kit, available with or without Water Pump https://www.evolutionm.net/forums/im...e_thumbsup.gif https://shop.boostinperformance.com/...&Submit=Submit Contact us for a quote to have your Timing Components Replaced, while you wait in our showroom! Ask us about some of the our other maintenance services we offer, including...... - Drivetrain Fluid Flushes - Oil Filter & Oil Change - Brake & Rotor Replacement - Clutch Installation & Flywheel Resurfacing - Injector Cleaning Services - AND MORE!! |
Ever consider throwing into the kit a tensioner pully adjustment tool and a plastic lock for the cam sprockets? Coolant flush I can buy anywhere.
Visit our website to order your DSM / Evo Timing Belt Kit, or contact us for a quote for Replacement of all Timing Components.
Ttt
