can't rev past 4.5k
https://www.evolutionm.net/forums/sh...ad.php?t=98594
does anyone know what the two "knobs" are onthe hks eids? it might be causing the problem, but i cant read japanese and would like to know if it is a tuning problem. thanks viet |
You have the wires from maf and to ecu reversed. One knob doesn't get used, the other one I set at \ , exactly like that. Almost near the top, but still a bit aways. I'd say the 10-oclock position. Reverse the wires from maf and to ecu, and your problem will be fixed :)
would that be the white and yellow wires.. where you had to cut the wire in half and connect the eids to both ends?
will try later tonight. thanks |
| All times are GMT -7. The time now is 08:58 AM. |
