HID turned into yellowish....
Old Jan 2, 2005 | 08:43 PM
RyongCE's Avatar
hello people.
First, my car is 03 evo.
It was yesterday! that the headlights turned into yellowish white.
Why did this happen???
do I have to get new ones or can I just change bulb???
PLEASEPLEASE!!! help
thanks!
Old Jan 2, 2005 | 08:46 PM
EVOTEXAS's Avatar
What color did they used to be?
Old Jan 2, 2005 | 08:50 PM
KILTERMAN's Avatar
Mine are a fine white with a tint of purple , how would they turn a yellow? bright like a banana yellow?
Old Jan 2, 2005 | 09:23 PM
ezhangin's Avatar
thats...bizzare
maybe the ballast went out on one of the bulbs, my HIDs aren't exactly the same color
Old Jan 2, 2005 | 09:37 PM
plokivos's Avatar
must be your headlight cover turned yellow.
That or you're running it with your fog lights.
no, you can't "adjust" the hid, you could change the bulb and ballast to cooler color but that's pia.
Check your headlight and if it's not your headlight, see the dealer, or goto a tuner shop.
4500 isn't really quite blue, its more yellow than blue for HID standard.
theblue's Avatar
Originally Posted by RyongCE
hello people.
thanks!
I hear some EVOs come with this great thing where you can go back to the dealer and they will fix broken stuff on your new car
Old Jan 2, 2005 | 09:40 PM
plokivos's Avatar
If you're talking about warranty, he may not have one. I'm almost out of my warranty, but what warranty?
So far, the dealers fcked up one other thing every time I goto fix something.
Old Jan 3, 2005 | 05:45 AM
kdogg's Avatar
Stock '03 EVO HIDs are rated to be yellowish white. Only certain angles do you see any white/blue. I never saw any purple. From other stories for bad ballasts, the HIDs turn red/dark purple. I think most of those owners were fixed under warranty. Good luck.
Old Jan 3, 2005 | 10:13 AM
ibanez_926's Avatar
mine sometimes turn yellow right when i turn them on but then turn to the regular color a second after
Old Jan 3, 2005 | 08:52 PM
Smokin Evo's Avatar
you could try replaced the bulb first.
Old Jan 4, 2005 | 12:34 PM
Wicked05's Avatar
4300-4500k usually is yellowish white...mostly white....but in some instances can look like a bright halogen....
the projector could tint it a bit blue or purple...depending on the angle....but mainly white...
Here are some pics of my buddy's 03...with upgraded HID bulbs in stock projector....(before and after shots)
there is a slight difference in color...stock is roughly 4300-4500k.....these after markets were about 6000k......dont' know where he got them, though......
both pics show his HID foglight upgrade as well......
anyhow....it's a huge pain to change the stock D2 bulbs....gotta take out the whole front clip....but not hard....just time consuming.....
hope this helps....
Attached Thumbnails HID turned into yellowish....-hid-fog-stock-hid.jpg   HID turned into yellowish....-hid-fog-upgraded-hid-projector.jpg
Old Jan 4, 2005 | 12:46 PM
SilverCOEvo's Avatar
I like the HID foglight upgrade...hrm...more things to do.
Back on-topic, I have an 03, and I don't think mine are yeller...I'll have to look more closely now, but they've always seemed pretty white/blue to me.
Old Jan 4, 2005 | 12:52 PM
Dustan78's Avatar
hey that happend to mine aswell...it turned yellow the like a pink color..i took it to the dealership and asked them wtf is this...and they had to replace my headlight unit altogather. it was covered. if you have anymore ?'s shoot me a pm. oh mine is an '03 as well.
Old Jan 4, 2005 | 08:00 PM
RyongCE's Avatar
Thank you all!
I guess I will have to go to dealership for replacement.
But they'v always tried to avoid these kind of things. I wonder if they will say " It's still working. why do you need to change it?"
Most Mitchu dealerships seem like they're trying not to help their customers.
Old Jan 4, 2005 | 09:08 PM
Secret Chimp's Avatar
How did you notice that the lights changed color? Are you sure it isn't all in your head?
I have heard that HID blubs 'fade' before they burn out. So if what you are seeing is real, you might want to change the bulb.
SC~
