All Part Number Request Go Here
Old Jan 2, 2007, 06:31 AM
  #1501
Spins4's Avatar
Originally Posted by wreckleford
Hi, I'm looking for the part number for the VIII piston rings. Also, I understand that the IX uses different rings - are the compatible with the VIII pistons (are VIII and IX pistons different?) and what's the part number for these? TIA
MN155259 for the VIII piston rings and the pistons are different. The VIII pistons are 1110A223, and the IX ones are 1110B073.
Old Jan 2, 2007, 06:32 AM
  #1502
Spins4's Avatar
Originally Posted by Matz
Well, I've searched for "inj" in the past 15 pages, and can't find a part number for the Evo8 fuel injectors. Could someone please post it? TIA!
MN153193
Old Jan 3, 2007, 06:22 PM
  #1503
evo8dad's Avatar
I am looking for the part number(s) for the stock vaccum lines that run from the wastegate/turbo to the OEM boost control solenoid and the restrictor pills if they are not included. Parts needed are for an VIII.
Old Jan 4, 2007, 07:05 AM
  #1504
Spins4's Avatar
Mitsu actually sells it as a hose assembly, which is cool. However, there are 3 different part numbers, so here is the break down for all of them in case anyone else may need it down the line.
12/02 - 7/04 : MN143555
8/04 - 7/05 : MN156396
8/05 - on : 1632A117
Old Jan 4, 2007, 07:46 AM
  #1505
evo8dad's Avatar
Thanks
Old Jan 4, 2007, 07:57 AM
  #1506
Spins4's Avatar
Thanks
No prob
Old Jan 4, 2007, 08:18 AM
  #1507
scorke's Avatar
I wish i lived in RI again just so I could get work done by your dealership haha. I hope they know how much evom and its members appreciate what you do spins4!!
Scorke
Old Jan 4, 2007, 08:58 AM
  #1508
Spins4's Avatar
Scorke
Aw, thanks man! As for them appreciating it, they better come reevaluation time
Either way though, I do like what I do. Especially when I have the time to "play" on here. Even if I'm not making sales, at least I like being helpful. One of the biggest things I tell alot of people, when it comes to dealing with vendors, I personally would rather deal with someone that is down to earth, rather then some jerk, that will just talk down to you, or not even make like they are interested in helping. And thats pretty much what I try to do.
But thanks again for the compliment, and keep the orders coming guys
Old Jan 4, 2007, 05:11 PM
  #1509
Xska555's Avatar
Need help with my parts list, could you possibly check to see if I have the right part#'s so far and give the me the numbers I have missing below also could you PM me a price qoute on these parts shipped to N.Y. 11757, Thnaks
Cam angle sensor assembly
MD344722 - support, camshaft position sensor (basically the sensor body)
MF140025 - bolt, cylinder head flange (qty 2)
MD329503 - gasket, cam position sensor
MD329502 - cover, cam position sensor
MF140204 - bolt, cam sensor cover (qty 3)
MD327107 - sensor, camshaft position
MD375814 - reluctor
MD368730 - reluctor bolt
Thermostat assembly
MN143306 - water inlet pipe
MF140021 - bolt
MD363251 - thermostat outlet pipe
MF140207 - bolt
MN143307 - thermostat housing
MF140239 - long bolt (qty 2)
MF140227 - short bolt
MD363254 - gasket
________ - Thermostat
________ - Water pipe O-ring
________ - coolant temp. sensor
Rear, timing belt shields
MD322517 - upper left
MF140202 - bolt (qty4)
MD334401 - upper right
MF140202 - bolt (qty 4)
MD181864 - plug
MD373065 - lower (no bolts shown)
Misc.
MN143079 - lower timing belt cover
MD310447 - intake manifold gasket
MN163343 - oil pan
________ - oil pan bolts
MD050316 - oil drain plug
MD050317 - oil drain plug crush washer
________ - 2 bolts for turbo oil return flange, oilpan side
________ - water temp sensor
MR578117 - knock sensor
MN100169 - throttle cable
MD180361 - throttle body gasket
MR323654 - exhaust Manifold gasket
MD340535 - valve cover gasket
_________ - front brackets for engine hoist w/ bolts
_________ - rear bracket for engine hoist w/ bolts
also all the nuts/bolts/washers to attach the intake manifold to the head
99-03 Galant 2.4 OEM parts:
________ - water pump
________ - oil pump
MD156604 - timing belt pulley
MD308086 - timing belt tensioner
MD182537 - timing belt tensioner pulley
________ - front crank seal
________ - rear main seal
________ - gasket, oil filter housing
________ - coolant overflow resivoir
1994 Galant 2.4 DOHC parts:
________ - timing belt
Old Jan 4, 2007, 07:41 PM
  #1510
evo_skillz's Avatar
I'm looking for the stock clock that's on the dash,...where can I find it. Mine is scratched and it bothers me every time I look at it. Unless you guys know how to take the scratch off.
Old Jan 5, 2007, 08:57 AM
  #1511
Spins4's Avatar
Believe it or not, that stupid little clock would run $106 . Part number MR962799 ... so how bad is that scratch..lol
Old Jan 5, 2007, 08:59 AM
  #1512
Spins4's Avatar
I'll see what I can do...flyin solo this week, so I have not had a whole lot of time to even check here and the other forums .
MD375814 - reluctor
Thermostat assembly
MF140021 - bolt
MF140207 - bolt
MD363254 - gasket
MD181864 - plug
Misc.
MN163343 - oil pan
________ - oil pump
Old Jan 6, 2007, 07:34 AM
  #1513
Spins4's Avatar
Ok, here goes.....
MD344722 - support, camshaft position sensor:$23.08
MF140025 - bolt, cylinder head flange (qty 2):$.74ea
MD329503 - gasket, cam position sensor: $8.36
MD329502 - cover, cam position sensor: $2.94
MF140204 - bolt, cam sensor cover (qty 3): $1.02ea
MD327107 - sensor, camshaft position: $47.26
MD375814 - reluctor: $10.38
MD368730 - reluctor bolt: $1.74
Thermostat assembly
MN143306 - water inlet pipe: $64.94
MF140021 - bolt: $.30
MD363251 - thermostat outlet pipe: $22.66
MF140207 - bolt: $.30
MN143307 - thermostat housing: $68.20
MF140239 - long bolt (qty 2): $1.23ea
MF140227 - short bolt: $.62
MD363254 - gasket: $.66
MN143463 - Thermostat: $13.06
MD030764 - Water pipe O-ring: $2.42
MD177572 - coolant temp. sensor: $33.42
MD322517 - upper left: $6.44
MF140202 - bolt (qty4): $.30ea
MD334401 - upper right: $12.00
MF140202 - bolt (qty 4): $.30ea
MD181864 - plug: $2.82
MD373065 - lower (no bolts shown): $16.16
Misc.
MN143079 - lower timing belt cover: $45.44
MD310447 - intake manifold gasket: $7.46
MN163343 - oil pan: $118.14
MD097012 (17?) & MF140201 (2) - oil pan bolts: $.92 & $.74ea
MD050316 - oil drain plug: $4.04
MD050317 - oil drain plug crush washer: $1.18
MN156739 - 2 bolts for turbo oil return flange, oilpan side: $1.08ea
MR497720 - washers for above: $.50ea
MD091056 - water temp sensor: $22.14
MR578117 - knock sensor: $62.08
MN100169 - throttle cable: $23.86
MD180361 - throttle body gasket: $1.86
MR323654 - exhaust Manifold gasket: $11.50
MD340535 - valve cover gasket: $24.96
MD186785 - spark plug seals (4): $4.02ea
MD196781 w/ (1)MF241251 & (1)MF241253 - front bracket for engine hoist w/ bolts: $3.06, $.96, $.74
MD196781 w/same bolts as above - rear bracket for engine hoist w/ bolts: Same as above
(1)MF241258: $.58, (1)MF241284: $.94, (6)MF241258: $.84ea, (2)MS401452: $1.46ea, (2)MF430122: $3.28ea, (2)MF450406: $.82ea
MD976464 - water pump: $149.04
MD366260 - oil pump: $172.10
MD156604 - timing belt pulley: $29.86
MD308086 - timing belt tensioner: $64.36
MD182537 - timing belt tensioner pulley: $26.26
MD343563 - front crank seal: $12.22
MD359158 - rear main seal: $14.50
MD322521 - gasket, oil filter housing: $6.76
MR212510 - coolant overflow resivoir: $23.00
MD182294 - timing belt: $63.74
Now shipping would be based on the actual weight. But I tell you what, you place this entire order, shipping is on me.
Old Jan 8, 2007, 01:00 AM
  #1514
Ads77's Avatar
MR interior parts
Hey guys, chasing up part numbers for the new Evo IX MR chrome metallic painted inner door handles and accent panel and the gloss piano black radio surround and dashboard panel that has just been released on the new MR or JDM 9.5 , any help greatly appreciated
Old Jan 8, 2007, 03:59 PM
  #1515
southcalihds's Avatar
Quick Reply: All Part Number Request Go Here
