EVO RS Purchase Questions
Guys,
Contenplating the RS, so I have a few Q's
1. Is 27,000 a GOOD Price, or should I push for less?
2. The MAIN Reason I'm buying is of course the LOW ET, so can I reasonably
expect 13.1 @ 102 like the mags are getting. I'll be using 94-98 Octane at
sea level.
3. Coming from the Turbo Buick camp, I've had 5 Low 12 Sec Buicks over the last
15 years, is it Reasonable to expect high 12's for LESS Than $1000??
4. I don't give a Crap about music, but apparantly the RS comes without a radio,
Whats the Cheapest I can a Stereo for, and Cassete is even fine??
5. Has anyone Removed the front sway bar for better weight tranfer at the
Track(Drags of course)?
THANK YOU In Adavance!!!
sea level.
1. Paid $25,500 for my 04 RS, but the 05s cost more.
2. Not sure what the question is. Expect some variation between cars.
3. Yes. But you'll need to replace the clutch fairly soon if you do much dragging, and that will cost some $$$, especially if you can't do the work yourself.
4. I bought a stock Evo radio for $50. It's an easy plug in because the RS's are wired the same.
5. Don't worry. Traction won't be a problem, especially at that power level.
I thought the 276HP Lightweight EVO RS just came out?? How could you have an 04??
And as for the Clutch, isn't that covered under warranty?? As long as you keep the car stock they HAVE to Fix/Replace it!!
And do I need to buy a JUST a head unit, or Speakers as well??
11SECEVO,
1. I payed 27K for my 2005 Rally Red RS
2. The time's posted in the mags are attainable, but the cluch would be the weak link.
3. I am sure 12's are easly done with a few bolt ons
4. Radio is pre-wired so it takes very little effort to install head unit and speakers
5. Can't comment on front sway bar?
Buy the Evo RS you will love it!
Best of luck
Best of luck
Originally Posted by EVO8LTW
. Clutch is not going to be covered under warranty. .
I have an 04 RS. Don't expect the clutch or anything else to be warrantied once you start modding the car. They are pretty much refusing most warranty work on evo's. If I wanted a car for the 1/4 mile I wouldn't buy an evo. If you drag race the car you will kill the clutch fast and your transmission probably will be next.
Then what the heck does BUMPER TO BUMPER Mean??? If the car is STOCK they have NO CHOICE but to FIX/REPLACE the clutch!!!!!!!!!
By the way, are you planning on staying stock with that screen name?
Guys, my buddy had his Clutch Replaced Twice on his '04 EVO 8
UNDER WARRANTY and YES he raced it, and NO they had NO WAY of Knowing that!!! It was at Golden Mitsubishi in the Reading PA Area!!
Guys,
sea level.
sea level.
