alarm and turbo timer help
Old Mar 19, 2005 | 02:16 AM
Derek888's Avatar
This is how my alarm works. When I start the car the doors auto lock after 10 seconds and when the engine stops the doors unlock automatically. The problem is when my turbo timer is running I lock the doors with the alar remotem and when the engien shuts off using the turbo timer the doors unlock again. Any way to fix this?
Old Mar 19, 2005 | 04:10 AM
BMan's Avatar
I think you will have to turn off the auto-lock/unlock function.
Old Mar 19, 2005 | 05:59 AM
4ce fed's Avatar
Sure. Tie the Yellow wire from the alarm to the accessory circuit instead of the ignition circuit of the car. That is the easiest way to do it. This assumes that you don't have the turbo timer hooked to the accessory circuit. There really is no need for it to be.
Old Sep 3, 2005 | 01:57 PM
titaniumkingpin's Avatar
im not understanding this..... so there is a way to get a factory alarm to work with a TT?
So, yellow wire from alarm to the accessory circuit instead of the ignition circuit.
Someone please clarify.
Old Sep 3, 2005 | 02:15 PM
Jakeg97's Avatar
http://www.evomoto.com/tech_info.php...3_5&tech_id=24
