Apexi Power Intake with MAF hardpipe
Originally Posted by EvoJimbo
I think you and I have covered this topic many times. the combo works great. I just couldnt find a way to use the brackets that came with the power intake so I left it resting.
bingo. resting on the resevoir?
Originally Posted by nick735
93civEJ1, do you have a pic of the hks/apexi intake installed? I think im going to take a picture today and maybe we can compre them...
Nick735 got his to fit perfectly and was able to use the brackets that came with the Apexi intake kit. The key is to find out which one MAF pipe he has. He has HKS Suction kit listed in his signature.
Nick735: Did you buy the HKS RS kit and not use the filter? Or did you just buy the pipe by itselft, that was supposed to be used with the stock air box. Boost solutions used to have that stock airbox MAF pipe on their website, along with the part number. I havent been able to find that part number listed anywhere since there website shutdown. It was originally fitted for the Evo 7.
Brian
Brian
Originally Posted by TURBODAWG
Oh he just used one bracket. Which one, the one supporting the intercooler pipe too or the one that goes under the filter that is a biotch to get too.
Brian
Brian
there are actually 3 brackets, one close to strut tower, one more front, and the IC brace. I personally am using none of them with this combo. Its no where close enough.
Originally Posted by RyongCE
well, I have Apexi intake filter with a hardpipe..
Actually mine fits pretty well tho...
I just don't know the name of the hardpipe...lol..
Ill try to take picture of it.. !
Here is the pipe that I am talking about. Hope the link works: http://translate.google.com/translat...lr%3D%26sa%3DN
Part number is HKS p/n 1302-SM006. It says failure with HKS power flow intake (translated stock air box fitment)
Brian
Brian
I bought the pipe seperatly from boost solutions so it must be the pipe for the airbox. As far as the bracket that is hooked up, its the top bracket not the one on the bottom that is basically impossible to install.
If you just bought the pipe itself from Boost solutions, for like $145 or so, then that is part number 1302-SM006.
There are 2 brackets that bolt to the filter, then there is the one bracket that shares the bolt with the front bracket (closest to the bumper), that is the one that bolts to the intercooler pipe. You hooked up the front two brackets using that one hole, but didnt bolt up the rear bracket? Is that correct? Could you bolt up the rear bracket if you wanted to go to the trouble?
Brian
Brian
Just kidding... not trying to be mean...
