double clutch shift
Old May 25, 2005 | 07:15 PM
yesevo's Avatar
double clutch shift
my boy showed me how to shift gears fast without dropping rpms between gears....
the way he shift he didnt drop rpm and throw me back in the seat !
anyone know how to do it? detail info please how-to... and is there any side affect?
Old May 25, 2005 | 08:38 PM
t3t418t's Avatar
i believe its like this:
1. you let the clutch out to switch gears, lets say from 3rd to 4th
2. as you shift to fourth, you rev match the rpms to what it was before you let the clutch out.
3. then finish shifting into 4th and release the clutch as usual.
should end up as seamless a shift as it can get.
someone correct if im wrong.
Old May 25, 2005 | 09:28 PM
Hiboost's Avatar
Watch the welds on the intake manifold...
Old May 25, 2005 | 09:33 PM
2GDSM's Avatar
Funny post, just rev match.
Old May 25, 2005 | 09:35 PM
2GDSM's Avatar
and by the way, if you shift quickly the engine wont have time to really drop rev's much. The double clutching you might be thinking of isnt really neccessary with new cars (late model) because of the synchros in the tranny. Back before they had syncros in the manual transmissions, double clutching was often neccessary to keep the shift going without throwing the car all over the place. I believe truckers nowadays still usually double clutch because they dont have syncros.
Old May 25, 2005 | 10:32 PM
ct9a gsr's Avatar
Your friend was probably "no-lift-shifting", aka "power-shifting", aka "flat-foot-shifting".
Simply shift gears the same way you would in a race, but don't lift you foot off of the gas.
This is usually done in conjunction with a 2-step rev-limiter and launch controller.
Old May 25, 2005 | 10:35 PM
Mivo's Avatar
haha i was so thinkin that same thing right when i clicked on the topic haha
Old May 25, 2005 | 11:35 PM
pb24dagrk's Avatar
i'm sure you meant power shifting
double clutching is used only when slowing down (let's say you are crusing in 4th and want to slow down, you depress clutch, put in neutral, brake and slow down, then depress clutch again to put it to 2nd..... vs. braking while in gear and then downshifting)...correct me if i'm wrong
it was misused in fast and furiousl (lol) just because it sounds cool like you are double shifting super fast haha
Old May 25, 2005 | 11:47 PM
rezo's Avatar
if you never dropped rpms between gears you would be at the redline the whole time & would never accelerate (which would only happen if you had massive wheel slip) soooo......
there really is no big secret to quickshifting, you just have to practice being quick and it will eventually come to you. your friend might have done some full throttle shifting, which i wouldnt recommend doing anywhere but on the drag strip as its really hard on your clutch
Old May 25, 2005 | 11:50 PM
racerhead2's Avatar
step on the clutch twice when shifting down a gear
Old May 26, 2005 | 12:03 AM
Mivo's Avatar
isnt that called head-toe or whateve? i forgot the name but its when you blip the throttle as you downshift very similar to power shifting.
Jakeg97's Avatar
lol
Old May 26, 2005 | 12:05 AM
dizzigital's Avatar
i think double clutching is everything you just said except you flutter the gas pedal while in neutral before clicking into the lower gear.
Old May 26, 2005 | 12:15 AM
fshwcrs's Avatar
double clutching is when you are in gear, clutch in, put it into neutral, clutch out, blip throttle, clutch in, put it into the lower gear, clutch out. its pointless though, because transmissions have synchros now, so youre wasting time by doing all the extra clutch work and shifting when you should be concentrating on braking and your line.
Old May 26, 2005 | 12:20 AM
bigballz's Avatar
is it just me or when u double clutch UP a gear it goes in smoother? I know u said its for older cars, but my shifts arent as notchy when i double clutch UP a gear. (Regular driving i'm talking about not racing)
btw, what your friend was doing is powershifting and i think its pretty much useless to be honest, well unless u want to kill your clutch. Just learn to switch gears faster.
In evo's to cant go too fast or you hear this bang noise. Anyone know what that is btw?
