HID lense
Old May 26, 2005 | 11:31 PM
SIC SIK SIX's Avatar
Question HID lense
i have a 05 evo that did not come w/ hid. i bought an hid kit for it. my question is, are the lenses in the my headlights the same with the evo's that came with hid
Old May 26, 2005 | 11:36 PM
Curt@MrLed's Avatar
Former Vendor
https://www.evolutionm.net/forums/sh...hreadid=131680
ask this guy he will know..
Old May 26, 2005 | 11:37 PM
i bought it from him
Old May 27, 2005 | 12:02 AM
Wicked05's Avatar
No...they are not the same lenses....
When you install the new aftermarkets, they will be better than stock...but they won't be as even as the stock OEM HIDs.....
I have an 05 GSR as well...I got my kit here http://xenondepot.com/category.php?category_id=9
...it is a Phillips kit....
A buddy of mine used to buy the Vision, and the McCulloch kits...but the ballasts go out alot on them....
Old May 27, 2005 | 12:04 AM
DCSilvrEvo's Avatar
WHAT? STOCK is the brightest you can get. If you go up 2 6000K your actually light is getting dimmer. And it is the same lens.
Old May 27, 2005 | 12:07 AM
Wicked05's Avatar
correctomundo.....
I actually went with the 4300k kit to keep it closest to stock....plus...it keeps the po-po off my ***.....
Anyhow....What I was trying to get at is...the beam pattern will not be as even as the stock OEMS.
Old May 27, 2005 | 12:16 AM
so, which one is it Dcsilver says its the same lens, wicked says its different.
Old May 27, 2005 | 06:57 AM
Gary Bechtold's Avatar
I posted this before but it bears repeating...
4,200K is generally the stock color temperature that HID's from the factory come at. Anything else is just rice. Higher color temperature does not give you more light, it just means the color changed. Lumens is where the brightness is. The point of HID's is to see better.
Blue and purple may look "cool" but it is worse for visibility.
Old May 27, 2005 | 07:54 AM
fsugatorbait's Avatar
The optics of the projectors are different with the halogens than with the HIDs. I have an OEM PnP kit in mine and when im aimed at a wall at night you can see some scatter above the cut off line because of the halogen projector. Dont get me wrong though, its still a night and day difference than with the halogen bulbs, just not as good as if they came from the factory.
